Question about Dometic Rooftop RV Air Conditioner
How to stop leak from Dometic "Brisk air" RV AC into the living area?
    Guru:
  • 415 Answers
  • Start with the condensate drain. Your air conditioner collects condensate water from the evaporator (moisture that was in the air condenses and turns into water on the coil) where it then drains into a pan and then outside of the unit. Look for a drain and clear the blockage. If you have a wet/dry shop vac, you can vacuum out the drain area.
  • Make sure your air filter and your evaporator coil are clean. Clean as necessary.
  • Inspect seals and repair as necessary.
These are the first things you want to do and will, in most all cases, correct the problem you are experiencing. :-)
Posted on May 07, 2010
Dometic brisk 2 AC can it be operated on a 24 volt inverter.
If your inverter puts out enough power, sure. It may drain your batteries pretty fast, though. Check the power rating of your AC and compare it to the power output of the inverter. Add a safe margin for everything else you want to run at the same time.
Oct 29, 2015 | Dometic Rooftop RV Air Conditioner
Where can i get a replacement evaporator coil for a dometic rooftop ac
Depending on the area that you live, I would check with any compant that sells RV parts. If they do not have it check with a company calls Johnston Supply.
Jun 05, 2011 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
Quit blowing cold air
if a leak, should be repairable, a lot of techs these days find it easier and more profitable just to replace things. try a new tech
Sep 04, 2009 | Dometic Rooftop RV Air Conditioner
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Dometic air conditioner
1The air coditioner does run on Electric. 110V 2. No you do not have to unhook the battery 3. Yes you need to put water in the hot water heater so you do not burn the unit up.
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
235 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
