Question about Haier CPR09XH7 Portable Air Conditioner
My ac turns off every 20 minutes, is it on a timer or something?
  • 38 Answers
Check the tray sensor or thermistor
Posted on May 07, 2010
Timer of my panasonic inverter ac is blinking n aircon is not getting on. how do i resolve it
Unplug the power cord or if you are unable to turn off power that way, use fuse box and leave power off for 20 minutes. This should enable the system to reset to default settings and you can then set system to your needs.
May 06, 2016 | Panasonic Heating & Cooling
My AC gets automatically turn it off and flashing timer bulb.
First check the following first.
1. Keep the temp between 24 to 20 degree celcious
2. Check the air filters are cleaned
3. Check the power is correct.. if there is fluctuvation use stabiliser or booster
4. Check condensor coil is cleaned.
Conclusion. Every a/c must be cleaned once in 3 months and air filters are to be cleaned by every week.
Sep 11, 2015 | Heating & Cooling
LASKO 5624 will not turn on. The red light underneath the clock button is on. How do I reset? Is this broke after 20 uses?
Disconnect power, (unplug); wait for over 20 minutes, (have a cup of coffee); Depress power button before pluggging in to wall socket . (This will let any voltages that are stored in the unit drain off).
Plug in to AC outlet and press power to turn on.
If this doesn't work, Lasko has a 3 year warantee.
CUSTOMER SERVICE:
Toll-Free (800) 233-0268. Email: producthelp@laskoproducts.com
Feb 02, 2015 | Lasko 5624 1500 Watt Convection Heater w/...
I have a 1994 Silverado 1500. the AC works but a vent or something closes after 20 minutes or so. The fan continues to blow but the air stream is obviously restricted. I can turn off the AC and turn on the...
could be a leaking servo pipe. if it is knob turn type. motor failing on electric type. or a warn linc on vent control. very hard to find out you need to get your hand round the back and feel for the motor/s. on electric type. knob type with engine off move the vent control should hear a hissssing sound if no hissing sound then it is leaking.
Sep 26, 2013 | 2003 Chevrolet Silverado 2500HD
I have an Darlac Electronic water timer DW253 but haver mislaid the instructions, where can I download a set?
I cannot find a manual for the Darlac DW253.
It appears the timer is set by moving each selector knob.
http://www.watermate.co.uk/secure/uploads/DW253%20(Small)%20new%20darlac%20pop.jpg
Knob on right is Run Time:
This is how many minutes timer will run each time.
Set run time from 1 minute to 120 minutes.
Knob on right also has ON-OFF override.
Knob on left is Frequency:
This is how frequently the timer will turn ON. Once per hour, once per each 2 hours ... once per 24 hours ... once per 72 hour ... once per week.
So set frequency to 48 and set run time to 20, then every 48 hours the water will turn on for 20 minutes.
To turn timer off, move right knob to OFF.
For continuous watering, turn same knob to ON.
This timer is battery-powered, probably 9 Volt, but maybe AA.
Battery carriage appears to be located on front below the function knobs.
Typically, water timer batteries last one season.
Timer can be connected to household spigot, or connected to any passive water supply for example rain barrel or tank.
Appears to have standard female hose thread on top, or possibly 1/2 pipe thread, and quick connection on bottom.
Plastic water timer exposed to freezing temperatures can crack. Drain water out of timer during cold weather.
Generally if water timer stops working: replace battery, clean battery terminals, and if functionality is not restored, then buy another timer.
Add a comment to fill out the missing details.
Aug 02, 2011 | Woods Inwall 24 Hour Programmable Timer
Where can I get a wiring diagram for the intermatic t1975
Intermatic t1975 manual
Programming:
Depress trippers to turn on load
First tripper turns on timer for 16-20 minutes.
Each additional tripper lengthens time by 15 minutes
So if you want timer ON for 2 hours, you depress 8 successive trippers
Leave tripper up for OFF times
See manual for day-skipper details
Wiring:
T1975 has 120V clock motor
The load voltage is the same 120V
Timer can control 2 separate loads with SPDT
1) NO normally open pole (no electricity flows until timer turns ON)
2) NC normally closed pole (electricity always flows until timer turns ON)
This timer cannot control 240V load
Oct 06, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Dishwasher just started not filling enough water to wash dishes.
It does sound like a circuit board problem but lets not rush out and pay an exorbitant service fee yet...I checked the user manual and this model does have a timer also...so often timer go out and many people think the problem lies elsewhere...but when a timer goes out or a couple of teeth no longer engage then you could have any number of problems...I doubt the solenoid is bad or it would not initiate at all to begin with,,,,,so here is a little test......turn the DW on and cycle the timer to where it starts the water solenoid....watch the timer to see that it turns and disengages. the solenoid...How quick was it? (if under your accustomed 2 mins... problem with timer). Another test is to do the same and hold the timer tightly preventing it from turning and see if you can force the fill valve to stay open longer (if so...bad timer).
I hope this helps...please rate me....The Fang
Mar 12, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
Haier CPR09XH7 Portable Air Conditioner Logo
116 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
