Question about Mitsubishi XL1XU Multimedia Projector
The Protectiopn circut is working
Last time when we started the Projector (Mitsubishi XL1XU) the "Power" Indicator was red an the "Lamp" indicator was green blinking, the Manual said if the Lamp Indicator stop blinking push power. If this not work replace the Lamp, we bought a new lamp but nothing happens same state as before. Reseting the Lamp timer had no effect same state.
Hope my english is not too bad, and you can understand my problem.
Maybe someone could help me with my problem
  • 2 more comments
  • NHuebner Mar 27, 2008
    Maybe, i have pressed < > and Power at the same time, but nothing happens, or is it another sequence
    I pressed the Buttons in this sequence i wrote, after that the Temp indicator lights green for a moment. Same State as before.
    I tried pressing up and down and power, nothing happens.
    Is there an sequence to set the projector on factory defaults or something like that, maybe a user presed some buttons on the remote, or something like that.
  • drhan Jun 04, 2008
    I bought a used Mitsubishi XL1XU and since I received it, it had a "change lamp" instruction as I turned it on. When I contacted the seller, I was told the lamp's been changed but I need to reset the timer which I ignored. I barely used it (possibly 10 times) when it turned off one day. The indicator on the lamp now is red. Is there a way to check if the lamp's truely been changed and reset the timer (manual wasn't sent with product). Thank you
  • Anonymous Jun 16, 2008
    Any Solutions? please... tried everything
I have the same problem with multiple XL1XUs. I have 4 that give a solid red light and blinking green lamp light even after installing a brand new bulb and resetting the timer.
What gives?
Posted on Jun 05, 2008
  • 563 Answers
Hi there
Did you check that your lamp hours were actually reset ?
Posted on Mar 27, 2008
  • Marnus Jacobs
    Marnus Jacobs Mar 27, 2008
    No that is the right sequence , did the indicator lihgt flicker twice after you did this ?
    Basically this model has what they call a new keypad and a old keypad.
    The new keypad is the way you described your resetting and the old is hold up and down arrow keys in and press the power button.
SOURCE:
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
Working but lamp warning on screen,lamp led flashing
Press < and > and Power buttons at the
same time on the projector to reset the
lamp hours counter
May 12, 2009 | Mitsubishi SL1U Multimedia Projector
Automatic power shut off
Hold right left and power all at the same time and it will reset...
Jul 23, 2008 | Mitsubishi XL1XU Multimedia Projector
Mitsubishi XL1XU Projector
Hi there
The most common cause for a Ballast to go faulty is power failures & power spikes and off course lightning.
I normally advise my clients to hook up a UPS to the Projector just to make the power supplied to the Projector more even and smooth.
Ballast problems however occurs more than often on any model of Mitsubishi I have found.
Oct 25, 2007 | Mitsubishi XL1XU Multimedia Projector
Mitsubishi XL1XU Multimedia Projector Logo
532 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Marvin
Marvin
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
