Question about Bosch 24 in. SGS4072 Free-standing Dishwasher
How do you remove the Decor Door on the Integrated
How do you remove the Decor Front Panel on the Integrated Bosch S9J1B Dishwasher?
SOURCE: Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Posted on May 22, 2007
Cerfer39
  • 709 Answers
SOURCE: Bosch Dishwasher
Hi ED, It sounds like a real problem here. If the springs are still in one piece, my best guess is to to remove the springs from the door. Then attach the springs to the dishwasher body first, then reattach the spring to the door. Not an easy job, good luck. If you have further problems check with www.repairclinic.com, as the repairguru there may be of more help.
Posted on Sep 26, 2007
SOURCE: front panel
Did you knock out the plug on the disposal before you hooked up the drain hose ?
Posted on Oct 30, 2007
SOURCE: neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Posted on May 05, 2008
  • 116 Answers
SOURCE: removing decor door
With the door open all of the way you should see a series or torx 20 (small star shaped round head) screws around the perimeter of the inner stainless steel door panel. The outer door is usually held on by the topmost 2 screws on the outer corners and 1 on either side of the door in the second position up from the bottom of the door. There may also be a catch under the panel which will require the door to be slid upwards a little.
Be careful when the panel releases as there is about 15 to 20 pounds of spring pressure and the door may want to snap shut.
There may also be a small plastic cap on either side of the door panel about 8 inches from the top. Under these caps is a screw which clamps the door panel down. It will have to be loosened or removed if there.
There is no danger in removing all of the torx screws from the inner panel if the door still will not release.
This is for the standard installation but bear in mind that not everyone follows the instructions when installing the panels...
I
Posted on Aug 05, 2008
The door of my Miele G646 SCI semi-integrated dishwasher has suddenly become stiff to move up or down. I am guessing there is a problem with the spring? Any suggestions what to try or how to get access?
Most probably the decor door has swollen and catching on adjoining cabinets. removed decor door via two screws down the left and right hand side of door and see if that helps. If springs snaps then the door will drop very quickly and take the skin off you shins
Jan 14, 2011 | Miele 24 in. G646SCi Plus Free-standing...
Without the decor panel on the dishwasher the door keeps springing back will this stop when we fit the decor panel
Normally there is a way to tighten the springs on the two sides of the doors. This is to compensate for the decor panel. If you don't have the decor panels you could ease the tension slightly by adjusting the spring nuts and that should stop the door springing back.
Will need to know the exact make and model of the dishwasher to work out the exact location of parts etc.
Oct 23, 2010 | Dishwashers
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Decor door help for Whirlpool ADG 7560/1 integrated dishwasher
call for service to change the outer panel.it takes about 15min.
Feb 24, 2010 | Whirlpool 24 in. ADG7540 Built-in...
We have a bosch integrated dishwasher with a broken handle. We can't get the cover off to replace it! There are no visible screws on door front and I am unsure about unscrewing the metal panel door in case...
On mine there is a 5mm hole on each side of the metal part of the door, about one third of the way down. Inside is a torx screw. Loosen these off a few turns and you should be able to pull the top of the decor panel towards you, (away from the door, not up). Then lift it up to release it from the lugs at the bottom of the door.
That works for mine - yours may be a different model, but it's likely to use a similar mechanism.
Jan 12, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher switched itself off during cycle - no power now
It is possible that some of the pips have been washed down into the drain pump and jammed the impellor, follow the drain hose back to the pump underneath of the dishwasher make sure the d/washer is switched off at the power supply before you attempt this, if you have reasonable mechanical skill you should be able to remove front of pump to clean it.
Oct 09, 2008 | Bosch Dishwashers
Fitting a new front panel to the NEFF 54432 integrated dishwasher
My Neff integrated dishwasher has two holding screws in the top corners and then two hidden screms half way down the side behind plastic covers. Loosen these side screws, remove the top two corner screws and then the door cover/panel should lift out of two lugs at the bottom.
Aug 13, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Removing decor door
I
Aug 05, 2008 | Bosch 24 in. SHV55M03GB Built-In...
Detergent latch install for Bosch SHU3307UC dishwasher
you need to remove the front panel of the dishwasher. you need to open the door and remove the 6 torx screws on the inside of the door, close the door and lift up and out to remove front panel. you wiil see the detergent assembly there
Jun 25, 2008 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Bosch 24 in. SGS4072 Free-standing Dishwasher Logo
178 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
