Question about Home
I want a faucet that shuts itself off (saves h2o).
I want a faucet that shuts itself off (saves water).
  • 33 Answers
Search for "touch faucet" (Delta and Kohler have a few) or search for touchless faucets (many manufacturers have these with a sensor like at public restrooms)
Posted on Aug 03, 2010
Water just trickles out of the waterfall faucet
Look for the obvious-take off the screen. Then you may have to venture into the faucet itself. If you have galvanized pluming, every time you shut the water off, scale will fall int the center of the piping without pressure and then when you open the faucet it tries to flow through small orifices.
Dec 13, 2013 | Garden
My PTG-42PVN h20 heater is allowing h2o temp to fluctuate from one extreme to another.
Does same thing happen at all faucets?
Are you getting error code?
You might have crossover problem with defective faucet cartridge.
Copy following links for troubleshoot resources:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Aug 08, 2012 | Rheem Water Heaters
I have a single handle belanger shower faucet- replaced cartridge and no hot water , Need help
Check the hot water shut off valve, when the washer fails sometimes the valve itself sticks closed, and sometimes the washer breaks up and clogs water passageways down stream...
To test, pull the hose off of the hot water shut off valve, open the valve and see if you have water flow. (route hose into a bucket, you need more that a small amount of water.....
If you have good water flow from the shut off valve, then you likely have a particle that has lodged in the passageways of the faucet. Reverse flow with air pressure and see what you get out....
Jul 17, 2011 | Plumbing
My kitchen faucet has low water pressure both hot & cold. My faucet is a Bixby 538. I removed the spray head and the pressure is still very low. The pressure is good up to the shut off valves under...
If you have pressure to the shut off valves then most likely your shut off valves are not fully opening, I would recommend you replace both valves, they build up water deposits in them a lot of the times. The other possibility is the faucet itself has a water saver filter built into it. A lot of the new faucets have water savers built into them now.
Mar 15, 2011 | Price Pfister Plumbing
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Hot water trickles in swhower--works fine on other faucets--cold h2o flow fine
Clogged galvanized pipes. Replace with Pex or Copper lines. Or bad Moen cartridge- see department store for replacement or call Moen direct. You can get the # from gethuman.com
Nov 11, 2010 | Moen Posi-Temp Single HandleTub And Shower...
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
Home Logo
111 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
