Question about Mad Dog Multimedia (MD16XDVD9) DVD±RW Dual Layer Burner
Usb not recognized and no removable disk drive
    Brigadier General:
  • 10,406 Answers
Try connecting the USB device to a different USB port on the same computer, or to a USB port on a different computer, to confirm that the USB device itself is working correctly.
Posted on May 07, 2010
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
I got a seagate external drive 500 GB all my documents and picture are inside , any computers recognize it ,please help.
The unit has two major points:
* the disk-drive
* the USB-to-disk-drive adapter
So, disassemble the unit, and remove the disk-drive,
and connect it as a 'slave' drive in a desktop computer.
If it works, then that adapter has failed.
See: http://www.canadaram.com/3_5_sata_enclosures.htm
to buy a replacement enclosure for your disk-drive.
Oct 06, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My computer wont recognize my external hard drve and the io magic light is blinking
Try connecting the external hard-drive to a different computer. If it still fails, and it is still under warranty, then exercise the warranty to get it replaced.
If the warranty has expired, open the case, and remove the disk-drive, disconnecting it from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some desktop computer, to see if the disk is recognized.
If it is, then the USB-to-disk-drive adapter has failed, and you could go to any computer-store to buy a new external case and adapter, and mount your disk-drive inside the new case, and work with your files.
If the disk-drive is not recognized, check the warranty on the disk-drive itself.
Jun 24, 2010 | IO Magic Corporation GigaBank (I250HD35)...
USB device not recognized
Try another computer to see if it is the USB stick or your computer. Many times people will fry their USB sticks by not removing them properly. To remove, look for the USB logo on bottom right of your screen and right click, left click remove device.
Otherwise the computer may be writing to the USB stick and there is voltage still supplied to it.
Jun 26, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My computer does not recognize my WD external drive
You've tried different USB cables; so, that cannot be the problem.
You've tried connecting to different computers; so, the problem is _not_ your computer.
What's left is "inside" the case:
* the USB-to-disk-drive adapter,
* the disk-drive.
Open the case, and remove the disk-drive, and connect it as a "slave" drive to some computer.
If it is detected, then the USB-to-disk-drive adapter that has failed.
If it not detected, then the disk-drive itself has failed.
FInd the serial-number on the Western Digital disk-drive, and enter it onto Western Digital's web-site, on the "check-warranty" page. If it's older than 3 years, the warranty probably has expired, unless you were "lucky" and got a 5-year warranty.
Western Digital has a "Customer Loyalty" program -- just buy a new Passport through their web-site, and cite the serial-number, and you'll get a significant discount on _their_ price (could be higher than your local retail computer-store) for a new (probably larger) Passport.
Apr 05, 2010 | Western Digital WD Passport 250GB Portable...
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
Jan 04, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
'Please insert a disk in to the removable disk drive k"
Same thing happens to me .My 8gb silicon usb flash drive got the same error, please insert a disk into drive, the name of my drive weas changed into Removable Disk instead of the name(Sanctuary which is what i used) It said ni media ,and it was registered as XXXXXXXX U167CONTROL USB DEVICE can anyone help me with this.
Nov 25, 2009 | Electronics - Others
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
My san disk cruizer usb pen drive is not recognized by the pc
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 17, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Mad Dog Multimedia (MD16XDVD9) DVD±RW Dual Layer Burner Logo
135 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
