Wireless router setup
I'm trying to set up my Asus Wireless WL-520GC router for use with my Asus laptop and having problems. I've got the modem connected to the router via WAN but it won't go any further. It tells me there is an error without telling me what it is. Can anyone help?
  • 349 Answers
Is the problem that "nothing coming from the modem to the router"
if the router has more than one Lan port try the cable from the modem to the router, in the first lan port or the last port.
if its a wireless problem,ensure wireless is enabled on the laptop and the router,if you set up a security key ensure that it is put into the laptop wireless setting
sometimes you need to turn on the modem first then turn the router on after a little while to sort the ip address out before trying to connect the laptop, in the first instance.
hope this is of some help but more info would be good
good luck
Posted on Mar 28, 2008
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
I have same issue and using Asus WL-520GC
HI! I will be more than glad to assist u in this concern..the reason why page cant be displayed bcoz the router and the modem wont talk to each other.. u are connect to the router but not to the internet..this are the possible solution.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 30, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Cannot get other devices to connect to router ASUS WL-520GC
You might need to go into the setup on your router and be sure it is set to automatically give IP addresses to new devices.
Oct 01, 2017 | ASUS WIRELESS ROUTER |WL-520G - RT...
Asus WL-520GC wireless not working....
hi buddy!
first you configure the router to the modem ok
by typing the and follow the instruction ok
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 22, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Can not get my adsl modem to connect through ASUS wireless router
it could be the modem and the router has the same ip address. the asus router has an ip of, check if the dynalink modem has an ip of 192.168.1.x. if so, change the router's ip to 192.168.x.x (e.g. then see if you'll be able to connect to the internet while the modem is connected to the wan port of the router
Apr 02, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
The default IP address is
The manual is here:
Have you used the setup CD?
Nov 01, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Set up wireless router and modem Linksyss
It is not hard at all, but its alot of typing.
First have you tried following the manual to set it up?
Oct 22, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
