Question about Aprilaire 550 Humidifier
What is the saddle valve?
In the manual for my Aprilaire 550 humidifier, for summer shutdown it says, "Shut off the water supply to the humidifier by closing the saddle valve." What is a saddle valve and where is it? And if I turn the humidifier to "Off" is it OK to leave the water supply on all summer? Thank you.
    Guru:
  • 415 Answers
Your humidifier will have either a copper or plastic tubing attached to it. This tubing is the water tubing. If you follow that line to where it "taps" into a water line (near the water heater or a water line under your house), there should be a water shut-off valve. The water shut-off valve could be any type of valve but is normally a saddle valve. You could skip the step of shutting off this valve; however, it is good practice to shut the valve off for two reasons: 1. in the event of a water leak, you will be able to easily locate the valve to shut off the water. 2. if the valve is not "excercised" from time to time, the seals will dry rot and the valve will not be capable of doing it's job when the need arises.
Here is a video showing you how to trace your water line to your saddle valve. There is additional information on the video that you might find helpful as well.
Posted on May 07, 2010
Problem with 2 ....1 on each furnance Aprilaire 700 Humidifiers.. no fan no soilinoid click red light on one when furnance is runing they both worked last year
Odd for both to be out. Check the water supply sometimes corrosion or scale will block the saddle piercing valve. Run it all the way into the pipe. Usually need to spin the little valve handle clockwise. Then back it all the way back to full open and reset humidifier power and furnace power. After that may want to crack open water supply connection right before the solenoid at each humidifier to make sure water is getting to them.
Nov 30, 2013 | Aprilaire 700 Humidifier
No water to furnace humidifier
It's probably the saddle valve. The self-piercing needle rusts and clogs the water line. Replace the saddle valve with a non self piercing one. Also, check the voltage to the solenoid valve on the humidifier. You should be getting 24 ac volts. If not, replace the transformer. If voltage is present and still no water, then replace the solenoid valve (very expensive).
Aug 18, 2012 | Aprilaire 550 Humidifier
I need to replace the solenoid on a 560. Can someone point me to where I can find directions to do this?
Hello, turn the water off at the saddle valve and turn off your Furnace. Then disconnect the wires from the solenoid and disconnect the supply water tubing from the solenoid and the outlet tubing, now unscrew the solenoid and replace it with new one and reconnect everything and open saddle valve and turn Furnace back on.
Dec 10, 2011 | Aprilaire 550 Humidifier
How do I get the water flowing once it becomes clogged with sediment?
Hello, usually the inlet of the solenoid has a strainer that can be removed and cleaned of the sediment. Also, there could be sediment at the saddle valve where in this case you would have to shut off the water supply and clean the valve.
Feb 27, 2011 | Aprilaire 550 Humidifier
Aprilaire 550 making loud noise - sound like not enough water going through pump?
Hello, check to see that the inlet strainer into the solenoid is clean and no sediment has built up in it, also make sure the outlet of the saddle valve is clear and there is no sediment there.
Feb 14, 2011 | Aprilaire 550 Humidifier
I need to change the water panel on my humidifier but don't know where to turn off the water supply. Any ideas? Thanks
Hello, the water supply should be shut off at the saddle valve. I will post a pic of the saddle valve.robhvac47_11.jpg
Jan 26, 2011 | Aprilaire 700 Humidifier
There is no water reaching my AprilAire humidifier, indeed no water is flowing through the saddle valve attached to the hot water pipe of the hot water heater. Considering what would be involved in...
Yes a new valve seems in order. and yes having the valve on the cold side would create less build up in the filter pad so long as your water dose not come in at 37 degrees. but, I think you have it right.
Dec 22, 2010 | Aprilaire 550 Humidifier
We have an old Aprilaire humidifier (Manual adjust)and having problems trying to figure out how to shut it off-for the summer.
close the by pass air flow valve. shut off the water supply and finally flow the thermostat wire to the transformer or the controller and shut off or disconnect. Unit should be serviced before winter. Cell may need to be replaced
Aug 10, 2009 | Aprilaire 550 Humidifier
Need to shut off aprilaire model 550 humidifier
you should have a humidistat that should shut it off when set to zero. if the water solenoid is stuck, water will keep coming out even when the system is not heating. all humdifiers will have a water line ran to them. yours is most likely a 1/4"copper line that runs from the water solenoid on the side or bottom of the humidifier to a saddle valve on one of your water lines. this saddle valve is usually installed very close to the water heater. follow the line to the valve and shut the water off. sometimes you have to loosed the nut on the water valve to get it to turn easily. do not loosend the nut more the 1/4 turn and then make sure you tighten it back down after shutting the water off.
Jan 27, 2009 | Aprilaire 550 Humidifier
Routing waterline to pad
1/4" flexible copper pipe. Tap into your cold water line using the included saddle valve (pierces the pipe), attach the 1/4" flexible copper pipe to the saddle valve on the cold water pipe and the solenoid valve on humidifier unit using the included compression fittings. Tada!
Dec 10, 2008 | Aprilaire 550 Humidifier
Aprilaire 550 Humidifier Logo
1,324 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
