Question about Carrier Heating & Cooling
Wiring carrier model ZONECC2KIT01-B - Carrier Heating & Cooling
Fanblade caught wire harness on carrier ac model number 50zh 636-391 think it is blue to wht, blue to white
Sounds like a replacement motor. Those wires are likely for clockwise/counterclockwise. Hook it up and make sure air is blowing out or "up". If not reverse wires.
Oct 08, 2016 | Carrier Heating & Cooling
Carrier model 38tdb air conditioning unit kicks out the 40 amp breaker. Also moisture under compressor unit outside. What is problem?
What breaker? The breaker for the condenser? Likely have a compressor shorted to ground or drawing locked rotor amps. Easiest way to tell is make sure breaker off, unhook compressor wires from contactor. Turn on breaker and turn on machine. If the breaker does not trip, obviously problem with compressor
Jul 14, 2016 | Carrier Heating & Cooling
How do I find the part # for a compressor wiring harness for my Carrier model 38CKC060370 Air Conditioner?
carrier does not list a part number for this unit on a wiring harness. usually have to replace wires that are bad.
Mar 14, 2015 | Carrier Heating & Cooling
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
Where can i get wireing diagram for my carrier central air conditioner model 50zpa
www.xpedio.carrier.com/idc/groups/public/documents/.../50zpa-1pd.pdfFile Format: PDF/Adobe Acrobat - Quick View
The 50ZPA unit is built in one basic cabinet size and features a ... sheet metal and makes the 50ZPA units lighter than other .... Engineers' Specification Guide . ...
Aug 24, 2011 | Carrier Heating & Cooling
I need a wiring schematic for a carrier heat pump model # 4082030300B0
Contact carrier. Give them the specs and they will send u a electrical schematic
Apr 06, 2011 | Carrier Heating & Cooling
Does not ignite error code flashes 6 times
Look on the reverse side of the removable front panel of the Carrier. Each model will have a wiring diagram and a diagnostic chart to help you pin point the issue. Without knowing the model number the error code means something different for each model.
Nov 20, 2010 | Carrier Heating & Cooling
Kw for Carrier 42G150H
this is the m# of the air handler take frunt panel off an were the wires go into the unit there sould be another sticker with the kw usally there are 10to 15 kw is an averge house
Mar 15, 2010 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
138 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
