Question about Sony VAIO TR1MP Notebook
HARD DRIVE FAILURE
MY LAPTOP IS SHOWING HARD DRIVE FAILURE DETECTED PLEASE BACK UP YOUR FILE. i WENT TO LOCAL SHOP AND REMOVED THE HARD DISK AND ASK ME TO REPLACE IT WITH THE NEW ONE THE PROBLEM IS I CANT FIND THE REPLACEMENT.pLEASE  HELP
  • Anonymous Jun 26, 2008
    hard drive failure detected please back up files. this is what my computer is showing..
  • 242 Answers
You have to look for a 1,8 inch IDE harddisk, like the Toshiba mk6006gah or mk4006gah.
I think you can find one on ebay. Also you can order by some webshops.
Posted on Mar 27, 2008
    Guru:
  • 377 Answers
Hi dear
just back up your harddrive in other computer just release first
oke
It goes right from the loading screen to this Boot Menu.
It's not showing you even have a hard drive to boot to. If your sure you have a hard drive it may need to be reseated. There is either a cover underneath the laptop or a slide out tray on the side. Unscrew the cover/tray and pull out the hard drive then just put it back in and try to start it. Hope this helps. If not u probably have a dead hard drive. But the computer is still good.
Oct 23, 2012 | Computers & Internet
It went in for service when we got it back it only turned on once. now when we turn it on the screen is black and on the top left corner the cursor is flashing and if you press on a key it makes a loud...
There are two possibilities, damaged memory and hard drive not detected or damaged. Most likely is, the hard drive is not detected or damaged. The characteristics of the hard drive is damaged, when you turn on your laptop, you are like the sound of this
To be sure, the hard drive is in trouble, press F2 to enter BIOS, check your hard drive, or check the hard drive is detected or not.
If the hard drive is not detected and didn't sound the hard drive is damaged (like in the video), the hard drive can be repaired and the data can be saved. Solution: take it to the Service Center.
If the hard drive is not detected and the sound of damaged hard drives, optical damage your hard drive. Solution: replace the hard drive.
Sep 23, 2011 | Computers & Internet
I have a sony vaio that all of sudden won't boot up, I Just get a black screen with a white blinking cursor...my LIFE is on this computer....please help!
The windows operational system has become corrupted or the hard drive has failed, you can try removing the hardware and reseat it back in place, this will sometimes get it going. If this fails take the laptop to a computer service centre to have the files saved and installed on a new hard drive.
Sep 18, 2011 | Compaq Presario PCCOM2232US Notebook
Smart failure hard disk 4 :wd1600bevt-222ct0-(si)
The error S.M.A.R.T. refers to Hard Drive hard drive that has detected damage to the disk and failure of the drive is imminent.
If the computer is booting to Windows after the SMART error, then back up all data on the disk immediately. The hard drive will need to be replaced to resolve this issue.
Also, I suggest that you start the Computer to BIOS and check whether the Hard Drive is detected in BIOS.
If the Hard Drive is detected in BIOS, then try to perform reinstalling Windows supplied in your computer once before getting the hard drive replaced.
Dec 20, 2010 | Toshiba Satellite A215-S5822 Laptop
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
My laptop had a ''smart failure predicted on hard disk 0: toshiba mk4025gas-(pm) Warning: immediately back up your data and replace youre hard disk drive. A failure may be imminent'' what does this...
This means that your laptop's motherboard has detected that the hard drive (where all of your data and operating system live) is operating outside of normal parameters. Hard drives are supposed to read/write/respond within specific parameters. If the drive stops operating within these parameters, it usually means that the drive is failing, and therefore your information should be backed up, and your drive should be replaced. Once you back up your data, you can contact HP support to get the hard drive replaced.
Mar 03, 2010 | HP Computers & Internet
PXE-E61: media test failure check cable
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 18, 2009 | HP Pavilion dv1000 Notebook
Hard drive failure compaq presario 2200
If the bios is showing no ide, means that your ide hard drive is not being detected.
This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
Nov 05, 2008 | HP Compaq Presario 2200 Notebook
Sony VAIO TR1MP Notebook Logo
109 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
