Question about Nintendo Wii Console
Our wii won't eject the disc. There seem to be two metal tabs blocking the opening.
My wii is doing the same. And i feel much better now that i know Someone else has this problem
Posted on May 17, 2010
I accidentally inserted a disc the wrong way in our Wii console and cannot get the disc out now - the eject button won't work, what should I do?
Check if you can see a small hole on the media drive or optical drive. Use a paper clip to manually eject the disc.
Hope this can resolve your concern.
Jun 26, 2011 | Nintendo Wii Console
My disks are not playing. It states. An error has occurred. Press the eject button and remove the disc,then turn the wii off and refer to the operations manual. I have tried everything
i am having this same problem.... found this bit of info, hope it helps.
The most common reason for the Wii not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
Jan 04, 2011 | Nintendo Video Game Consoles & Games
Wii unable to recognize the disc in Disc channel
http://store.richspsxparts.com/wiiredvddr.html
Apr 20, 2010 | Nintendo Wii Console
Disc won't eject.
When you hit eject do you hear it attempting to push out the disc? It may be blocked by something. If it is not attempting to push out the disc then something isn't registering with the eject button. In this case, power down the wii, unplug all plugs from the back, wait 90 seconds or so, plug in just the power plug and hit the eject button (before hitting power or anything else). If it still does not try to eject then either the button is broken or the disc drive in the wii has died.
It is still probably under warranty from Nintendo, they can fix it for free for you. If anything, give them a call at:
1-800-255-3700
Jun 25, 2009 | Nintendo Wii Console
Drop wii disc stuck
Your disc is stuck in Wii Console, It needs to eject manually.. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jan 20, 2009 | Nintendo Wii Console
Disc will not eject
your problem seems to be a failure in the Slot load Tray. it seems that the mechanism which assists in ejecting the Disc could require repairing/replacing.
i would suggest getting in touch with Nintendo customer services about this issue due to it being an internal hardware fault !
hope this helps ?!
Oct 27, 2008 | Nintendo Wii Console
Disk won't eject from wii
I looked it up at the troublshooting center on Nintendo.com, I found this: If a game freezes while playing, usually the power, reset, and eject buttons will not respond. Try unplugging the AC Adapter from the back of the console, then check the air vents to make sure they're not being blocked. If that does not help, it looks like you may have a problem with the wii itself. You should contact Nintendo customer support about how to get it repaired. You can call them at 1-800-255-3700. Hope it fixes it for you! Good luck! :)
Sep 07, 2008 | Nintendo Wii Console
Wii
hello micky1965
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform:
| Nintendo - Customer Service | Contact Us! |
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
riz.
althought i have a guide for opening inside the wii.?
Apr 08, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
