Question about Microwave Ovens
I have a Nespresso Lattissima F310. The button you use to get hot Water for tee. doesen´t light and I cannot get the hot Water. At the same time my Caffe Latte is luke warm. (98 F). I can get good. hot Espresso (150F). Why can I not get hot Water or war Caffe Latte?
  • bengt_brorso May 08, 2010
    Hi !
    Thank you for your help. I will get it to the seller.
    I bought it eight month ago. Do you think the garanti will cover it?
    When I press the button on the milk-container to clean it the water is hot.
    Do you know why the button for water not light up?
    Are there more then one heater?
    Sincerely
    Bengt
  • bengt_brorso May 10, 2010
    Thank you!
    I will get to the seller and use the warranty, that still is left.
    Sinserely
    Bengt
  • 1,284 Answers
Hi, the best option is to return it to the seller. It still has a warranty on it.
Take care
Posted on May 08, 2010
    Genius:
  • 1,040 Answers
Dear Bengt,
Your problem seem to be of mechanical, It may happen due to various factors. But most probably it happens due inefficient working of water heating unit.... or temperature meter set in your gadget to read water temperature.......
So best way is to get it serviced......
Posted on May 07, 2010
My TAPPAN Microwave Oven Model Type: TM5430 B only shows S1 in the display and it doesen't react if i push any othetr buttons. What can i do ???
Unplug the unit, let it sit for a minute to clear power from the control board then plug it back in. If the display still shows S1, that could indicate a bad touch switch on the front panel, a bad connection between the touch panel and the control or a failure in the control. Unless you can get parts cheap and fix it your self, it's not worth paying for the repair.
Jul 08, 2011 | Tappan Microwave Ovens
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
My nespresso started suddenly runnnig too short. Please help. Joe
Next time you fill your cup, try holding the button in until it gets to the desired level then let it go.
That should reset the fill amount setting so that from then on it fills to that amount when you just push the button once like you normally do.
Good luck.
Apr 16, 2011 | Microwave Ovens
Everything works. Time, fan, turntable, light. It
Magnetron and accompanying high voltage diode are usually to blame. Everything else works but the magnetron isn't resonating (providing the proper energy to excite your water molecules).
An appliance repairman can change it for you (typically $180) or you can get a new microwave.
Apr 12, 2011 | Sharp R-520KS Microwave Oven
We have an 8 year old Alessi Nespresso machine, and it is leaking water at the base. It seems to leak only when the machine is in use. There is not any water at the base of the water container, so i am...
I have the same model, same age, same problem. It appears to be the seal between the metal heating coils, and the plastic switch that selects steam or coffee. Possibly caused by no cleaning the injector hole with the tool provided with machine (which causes a lot of back pressure). On mine, the screw that holds the switch to the heater has corroded and can not be unscrewed, so not possible to access rubber seal, and repair. May be tricky since this is plastic sealed to hot metal with a rubber gasket. So fo now, i unscrewed the black base plate on the bootom, and set the Alessi in a tray. THen just wipe up water after use.
Dec 27, 2010 | Microwave Ovens
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
No heating or power to microwave oven
You have a fuse in the back that's problem is blown
Mar 13, 2009 | Microwave Ovens
MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Nov 25, 2007 | GE JVM1870 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
