Question about Tag Heuer cj1110.ba0576 Wristwatch
How to size my tiger woods watch
How to size the tiger woods watch i dont no how and i would like to where my watch not just look at it
    President:
  • 2,501 Answers
Try your local watch shop to see f they can do it for you.
If they can't, then locate your nearest TAG service center by going to http://csec.tagheuer.com/customer-service-centres/ and asking them to adivise you where to take it (or send it).
Posted on May 08, 2010
Does t. woods watch require pressure testing w/ battery replcmt?
As long as they don't charge you $40, it should be free. Having said that my machine for testing water resistance cost almost $5000. I have to recoup that somewhere. Now you know why it cost so much. Does it require testing, no. But kon't come crying to me your watch leaked and I was the last to open it. I told you it needed to be tested but you didn't want to spend the $40. That is the view from the other side of the bench.
Jun 22, 2012 | Tag Heuer Tiger Wood Golf WAE1111 Watch
A friend has a tag heuer tiger woods link that I think is non genuine. It does not have a screw down crown. Does not have a serial or model number on the back and does not say swiss made on the dial. Is it...
Take it to a store that sells them, they will be happy to determine if it is a fake. Take the opportunity to see, feel and appreciate what a real one feels like and you will probably be able to tell in future if it is fake or not. Beware, there are some good 'fakes' out there. And remember, Only fake people wear fake watches.
Sep 22, 2011 | Tag Heuer WAH1112.BT0714 Formula 1 watch
Tag Heuer Tiger Wood Golf WAE1111.FT6004 Watch stops when not worn. Is there a problem
An automatic watch needs to be worn, wound daily or placed on a watch winder to keep it going. It is not like a quartz watch that has a battery and can keep going when not worn. A modern automatic watch will run for about 36 - 48 hours on a full wind.
A quartz watch that stops like you describe is in need of a cleaning by a professional watchmaker. When this stopping occurs it is an indication the oils have dried out and the warmth from your body heats them so they are semi liquid again and the watch runs. but when the watch cools again the oils harden and the watch stops.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 21, 2010 | Tag Heuer Tiger Wood Golf WAE1111 Watch
How do you adjust a merona watch band
this is all the info available. Try to contact them yourself:
Merona AG
Birmensdorferstrasse 83
CH-8003 Zürich
Tel +41 44 465 80 80
Fax +41 44 463 16 96
E-Mail mail@merona.com
May 19, 2010 | Watches
How do I take out links to size my bulova tfx watch
You have to press the pin out of the side of the ban. I use a tool they sell at harbor freight tools to do it. If you dont have a harbor freight near you they have an online store. You can also use a good push pin and a small hammer to tap the pin out. Put the ban on it's side over a small hole drilled i a flat piece of wood so the pin can come out without bending. do this for each link you want out then tap the pin back in on the last link to put it back togather. Sometimes there is an arrow on the inside of the ban showing you the direction to drive the pin out
Oct 02, 2009 | Bulova Watch
Tag Heuer Tiger Woods watch stops regularly
You should go back to the watch repair shop and ask for complete check-out of your watch. No watchmaker can return the watch to the customer without properly checking all the gearwork, timekeeping, battery power and all the features the watch has.
As your watch was serviced and the battery replacement took place, the executives of all the work done are responsible for all the faults your watch is having right now.
As watch repairs are quite expensive and time consuming, they (probably) will argue with you about this issue, but DO NOT give up, as these are YOUR consumer rights to ask for the job to be properly done (under warranty or paid by you). In case if you will be turned down, ask for FULL refund and find another shop.
If the repair shop is ready to undertake the job again, do not rush them, as the complete watch overhaul and check may take up to 6 weeks (this MUST be done at no any cost to you if you have the warranty or allready paid for the job).
P.S. I suspect that there is some fault in your watch geartrain, because if it is shooked or moved, the watch works, but when idle-it stops. That means the service of your watch was NOT DONE properly, and some failure or even dirt in geartrain was missed by the watchmaker (sometimes it happens- nobody is perfect!). This doesn't mean you have to agree with it, so, go and get your watch properly serviced and checked out.
Do not forget to rate, please.
Mar 08, 2009 | Tag Heuer Tiger Wood Golf WAE1111 Watch
Link pins for a womens Fossil watch
The only place you can get them is at a watchrepair. Sometimes I have found wierd sized link holes and have had to make my own pins. I just take a small nail and file it to the size I need. If you have a dremmil tool with a sandpaper attachment it is so much easier! Take a nail that is a little bit longer than the link is and sand down in a slow graduating cone shape, make sure to top of the nail is a little bit wider than the hole on the top of the link. Once you have that , put the smaller end in the link , line up the other link so that the pin goes into both links , and then tap it in. The pin should go into the bottom of the links. It might be good to do this on a piece of wood so that if the pin goes a little through the bottom, you don't damage anything. Try to make the pin as tight as you can, and than file (or dremmil) the top and bottom to the links size. If you still have problems please let me know, and maybe I can help you further. Good luck!!!!!
Oct 27, 2008 | Fossil Watches
Tag tiger woods runs down over night
I have a couple of questions. Do you wear the watch all day? How is your activity level ? If the answers to these is yes and good, then the problem lies in the self winding mechanism.
Without seeing the watch it is imposable to give you a complete estimate of the work needed.
We offer free estimates and all our work is guaranteed.
Donald McPherson Certified Watchmaker AWCI
www.finewatchmaking.com
Oct 25, 2007 | Tag Heuer Link Automatic Chronometer...
Link Tiger Woods Limited Edition Number 398
The Battery might be dead. and if its a problem with the actual watch home repair might not be the best since its a nice watch. i would just take it to a watch repair shop and ask them. hope it was some help
Aug 24, 2007 | Tag Heuer Link Automatic Chronometer...
Tag Heuer cj1110.ba0576 Wristwatch Logo
105 people viewed this question
Top Tag Heuer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
