Question about AEG 24 in. Favorit 60870M Free-standing Dishwasher
Error code 30
Hi, i have an aeg 60870 dishwasher showing error code 30 and the pump is going all the time, even when you open the door, any suggestions of things i could try please?
  • jeff whelan Aug 24, 2008
    hi, i have an aeg 60870 dishwasher showing error code 30 and the pump is going all the time, even when you open the door, any suggestions of things i could try please?
I fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Posted on Mar 28, 2008
2 Suggested Answers
joe_lishman
  • 192 Answers
SOURCE: Hi, I have an aeg 60870 dishwasher showing error
Sounds like the Anti-Flood system activated (polystireen float at base of machiene coupled to a micro switch) the purpose of this system is to put the drain pump on and stops any other function on the machiene. The anti lood system activates when any amount of water appears on the bottom (caused by leaky pipe / blokked pipes / spills etc.) . Dry the water and rectify the leak. This should solve the problem.
Posted on Jan 19, 2010
AEG 40850 - pump noise and running for long time, eventually showing error 20
There is a problem with drainage. Check the drain line connected to the disposal or peatrap. Make sure it is not plugged. Otherwise you can disconnect the drain line and put a wet vac on it to try to clear the hose
May 20, 2016 | AEG Dishwashers
Type 60870 not heating water!Have a wiring giagram for trouble shooting?
Could be: faulty power board (completly or only relay for heating element), faulty wiring between heating element and power board, faulty heating element (interruption, short circuit or current leakage,on some heaters faulty thermal protection).
Depending on the model, the display shows the i60 fault code or the LED end of the program will flash 6 times (only model without display).
Dado
Mar 17, 2015 | AEG 24 in. Favorit 60870M Free-standing...
I have an AEG F55002ViOP dishwasher. It's making a strange grinding sound and showing error code 30. Can anyone advise how to solve this please.
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
The noise what you heard during operation indicates that something is blocking the drain pump.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage then check why the drain pump makes noise.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Good luck.
Dado
Oct 11, 2014 | AEG Dishwashers
Aeg 60870 dishwasher water not getting in. Error code.10
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Oct 04, 2014 | AEG Dishwashers
Dado
Oct 04, 2014 | AEG 24 in. Favorit 60870M Free-standing...
AEG Favorit 60870 Dishwasher not starting
Matthew, in most cases when a circuit board repeats the same action over and over, there was a short and loss of communication with associated controllers. Obviously you have power to the control unit, so that means the instructions from the controller to the solenoids is lacking. You are correct in assuming the board needs replacement, however you must determine is the cost for replacement is worth the time and effort. An old machine means one repair after the other. If its relatively new; then it may be worth it.
Mar 10, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Hi, I have an aeg 60870 dishwasher showing error code 30 and the pump is going all the time, even when you open the door, any suggestions of things i could try please?
Dec 21, 2009 | AEG 24 in. Favorit 60870M Free-standing...
AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Feb 14, 2008 | Dishwashers
AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Oct 24, 2007 | AEG Dishwashers
AEG 24 in. Favorit 60870M Free-standing Dishwasher Logo
1,962 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
