Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Bissell Proheat Problem
I'm not getting any water flow from my Bissell 25A3 deep cleaner. The tank is seated correctly. I get water flow thru the tool but not the floor cleaner.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hfjk
Posted on Sep 30, 2010
I need a diagram of the hose connection in a Bissell Proheat model 1699-r
Bissell Proheat Carpet Cleaner Parts & Repair Diagrams
www.vacpartswarehouse.com > BISSELL
The Bissell Proheat Series Vacuum Parts, Repair Schematics, & Accessories. ...Bissell Proheat Proheat Cleaner 25A3 ... Bissell Proheat Deep Cleaner 1699 ..
Aug 30, 2015 | Bissell Vacuums
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
Why won't my carpet cleaner spray out water?
Check Water Tank Cap Filter (it looks like a screen). and, check the Flow Indicator Filter (under the Flow Indicator). If that didn't help the try the Bissell Consumer Care at 1-800-237-7691
Aug 25, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat 2x carpet shampooer will not put out any water
Have you cleaned the filters? Check your User's Guide for directions. One is located under the Water Tank Cap (small screen) the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691 Hope that helps.
Jun 23, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do I clean my bissell PROheat 25A3 tough stain tool?
I have heard of people washing them in an empty dishwasher! Most people just buy a new one!- Justin Buy Bissell 314 9162 Tough Stain 3 Tool Assembly for Bissell Deep...
Mar 05, 2014 | Bis ProHeat Upright Deep Cleaner 25A3
I have a bissell pro heat carpet cleaner. It is model 25a3 and about 1 year old. no water comes out when I press the trigger to clean the floor. The tools attachment works fine, any ideas?
If you are getting water from the tool. But not at the floor the most likely problem is the heater is clogged with coagulated soap or minerals. You will need to separate the upper handle to get to the heater. Insure the machine is unplugged. Remove the cover from the heater making sure you don't lose the little gaskets on each screw. Clean the channels inside the heater and put the cover back on. Be aware of how you are Taking it apart so you will know how to reassemble it.
Oct 31, 2013 | Bissell 25A3 Proheat Upright Deep Heated...
Water not comimg out
There are a few things you can try before determining there is a clog or broken tank. Make sure both water and formula tanks have enough liquid in them, make sure the tank is seated correctly. If both are good, try turning the machine off, reseating the tank and restarting again, the pump may have lost prime. If none of these work, you may have a clog or crack in your tank. You will need to investigate for clogs or breaks.
Bissell Proheat parts
GoodVac.com
800-775-6586
Jan 08, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
No sign of water movement from cleaning heads
My Bissell ProHeat is not dispensing water thru the floor cleaning position. I get water flow thru the tool application. Any ideas???
Apr 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
1,218 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
