Question about Simrad Ap1603r Autopilot Ap16 Rc36 Rf300 Ac10 Rpu80
Selenoid bypass valve has failed
Where can I buy a new selenoid bypass valve for my simrad ap16
  • 64 Answers
Contact don@sun-me.net and he can help you.
Posted on Jun 14, 2010
Turn on normally, go to press auto.... nothing
Hi Ty
This sounds to me like a cabling problem. There is enough "horsepower" to turn the unit on, but the increased current required to actually run the thing isn't as robust as it needs to be.
I would start by checking the connections at the panel or battery. Make sure these are absolutely pristine. (i.e. Clean and tight) Pay particular attention to the terminals and/or crimp connectors, whichever are used. It doesn't take much corrosion here to render the autopilot inoperable. Let me know how you make out.
-Steve
Apr 14, 2015 | Navico Simrad AP16 Autopilot for Inboard...
2011 ford focus 1.8 clicking noise when start engine
Could be several problems - check the battery terminals to make sure they are clean. Next check the battery to see if it is fully charged. If both those items checked are OK then the next step is to check the starter.
Now the starter has a selenoid which engages and provides power to the starter motor when you turn the key to the start position.
If you only get a clicking noise then it could be the selenoid valve itself or the starter motor.. Some fords have the selenoid mounted on the firewall others are mounted on the starter motor itself.
So what you need to do next is bypass the selenoid valve and provide power directly to the starter - if the starter turns the engine over then the selenoid valve is the problem. If the starter motor doesn't turn the engine over then it's the starter motor and a replacement is necessary.
Hope this info helps.
Feb 22, 2015 | 2011 Ford Focus
My Ap16 Simrad control head died. Any idea of as to 1) where I might get it repaired and/or 2) where I might find a replacement?
Hi John
Boy, you're up against it on this one. The AP16 is a pretty old unit for sure. Here's the link to your owners manual.
I've come across one instance in my experience where although there was enough power showing to the control head, because of corrosion and broken wire strands, there simply was too much voltage drop and not enough current flow for the unit to function when it was turned on. After cutting back/fixing the soldered connections and reconnecting the cable, the unit was good to go.
I hope this information is able to help you out.
Good luck.
-Steve
http://www.simrad-yachting.com/Root/Operator%20Manual/SimradYachting/English/AP16_OM_EN_20221560F.pdf
You MIGHT get some joy contacting Simrad tech. at 1 800 628 4487
if you're in the US. If not, here's the link to their support page.
http://www.simrad-yachting.com/en-US/Contact-Us/
Dec 08, 2014 | Navico Simrad AP16 Autopilot for Inboard...
What should i do when i replaced my alternator and got a new battery, and the truck still needs to be jumped started after two days. what could be the problem??
Sounds like you need a new starter. Did you check it out before you replaced the alternator and battery?
Some vehicles have a seperate selenoid on the firewall that engages when you turn to switch to start the engine. Others have the selenoid mounted to the starter. I
I would first bypass the selenoid valve and provide power directly to the starter motor. If it starts then it's the selenoid. If it doesn't then it's the starter motor - may have a flat spot in the windings or possibly burned but not shorted windings in the motor.
Jul 06, 2014 | 1998 GMC Yukon
Why does my simrad ap16 say initializing and doesn't do anything else?
The fact that initialization cannot complete the task at hand is an indicator the device is not capable of accepting new instructions, the circuit prevents reestablishing current instructions from making changes to the unit, or you may need to pay for services to unlock various codes.
May 10, 2014 | Simrad AP16 Second Station
Starter problem 1997 FLSTS
see the diagram attached, and by pass it . GOD BLESS YOU07b0a924-114d-4fdb-a9c3-005a442421f7.gif4c66c703-1a35-40c8-931c-f38f83eeeeca.jpgHowever if the problem persist you must replace the starter unit.to out tolerance parts.
God bless you
Jul 11, 2013 | Motorcycles
Sterter problem
your safer bet is a new starter because if you are having those kind of problems its not long before more starts to happen, bad bushings etc. buy a new starter
Jul 11, 2013 | 1993 Harley Davidson FLSTF Fat boy
Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Oct 28, 2009 | Simrad Boating
Simrad ac10 current overload
Normally this is the electric motor causing this problem. Just went on a call and had the same thing. Checked voltage coming from the AC unit to the motor and had 12 vdc then put a new one in it's place and it solved the problem. You don't have to change the pump portion, just change the motor itself. Indeed you will have fluid leaking but many times it's better than plumbing in a new pump.
Feb 18, 2009 | Simrad Ac10 Course Computer
GPS/Fishfinder keeps dropping and restarting
Do a software upgrade to the CE33 unit and then a master reset by unplugging the power cable , then press and hold PWR and CLR buttoms while plugging back the power cable. Wait a couple of second while the software reloads and should run smooth....
NOTICE: All the previous data as routes, waypoints, etc that you had will be lost by the master reset.
Jan 27, 2009 | Simrad Ap1601r Elect Only Ap16 Rc36 Rf300...
Simrad Ap1603r Autopilot Ap16 Rc36 Rf300 Ac10 Rpu80 Logo
136 people viewed this question
Top Simrad Boating Experts
Michael Vincent Cruz
Steve
Steve
ray gallant
Are you a Simrad Boating Expert? Answer questions, earn points and help others
