How do i change the channel on a dlink dsl 2740r as it is interfearing with my wireless cctv reception
  • 4,281 Answers
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings then go to wireless channel type change it to 3 or 6 or 11 Then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 07, 2010
Port forwarding
WHEN YOU OPEN A PORT YOU NEED TO ASSIGN THE DEVICE THAT GOES ASSOCIATED WITH IT...LIKE PC1 IP 192.168.1.1
PC2 IP 192.168.1.2 THE PORT YOU WANT TO OPEN NEEDS TO BE ASSOCIATED TO EITHER PC1 0R PC2 WHICH EVER IS RUNNING YOUR APLICATION...TEKGODS.COM
Feb 18, 2013 | D-Link DSL-2740R Wireless N ADSL2 4-Port...
I forgot my wireless DLinks G604T passwords. I open the Dlink admin but can not find where the PW section is. Please help
You can download the manual from this WEB site.
ftp://files.dlink.com.au/products/DSL-G604T/REV_A/QuickInstallGuide/DSL-G604T_QIG_v1.00.pdf
Page 8 gives you instruction on changing the password.
Feb 23, 2011 | D-Link DSL-G604T Wireless Router
I just conected my DI-524 with a new cable modem
The first question is whether your change of service provider really has any connection with your new lack of range. If your new cable modem contains a wireless router, it's possible it is interfering with your old router. You only need one, so in that case you should remove your DLink and configure your wireless cable router to your satisfaction. Otherwise, you may have coincidentally picked up a new source of interference; you may want to change the channel on your DLink router to see if that improves your range. The third possibility is that your DLink radio is going sour with age -- it happens -- and may simply need replacement.
Nov 25, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link dsl - 2640u ' the lan is up but wireless no...
i have a dlink dsl2640u when i go in 192.168.1.1 and try to turn on the wireless and save it reboots 3 to 4 times then it stays on but the wireless is off any help
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
How do I change channels on the 4 Port Wireless Router, ADSL2/2+. Need to change from channel 9 to channel 1.
Manual for DSL-2640B:
ftp://ftp.dlink.co.uk/dsl_routers_modems/dsl-2640b/DSL-2640B_Manual_v1.pdf
How to change channels see page 27.
For manual channel setting "Enable Auto Channel Scan" needs to be
disabled / not selected.
Note: default login user and password for the router is both admin.
Login opening Internet Explorer entering http://192.168.1.1 as address page.
Sep 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I need to change the channel on my dlink 625 router..can u help?
I presume it's a cordless phone? If so, it's possible that it's interfering with the wireless signal. If that happens you will see the wireless connection being dropped - go into the wifi config utility and check how good the connection is. If this is the case, changing the channel may help. To do that,bring the router over to your PC and connect with an ethernet cable (just in case something goes wrong with the channel change and you lose the wireless signal.).
You need to find the "router homepage" in your web browser. If you don't know what it is, in windows click start -> run -> type "cmd" and press enter. In the command screen that pops up type "ipconfig" and press enter. It'll show you a few things. One should say "Default Gateway" followed by numbers.Write those numbers down (probably will be something like 192.168.1.254).
Open your web browser (IE, Firefox etc...) and enter the numbers. This will bring you to the router page. There should be an option like "Wireless" and under there you should see "change channel". It may be in the advanced option window.
IF your computer is NOT dropping the wireless signal when the phone rings, but the internet connection does drop - check the DSL signal light on your dlink. If it is flashing or not on, then the problem is with the DSL filters (small white connectors sent with your modem.). Always ensure any phone on the same line as the DSL is filtered or it will cause the internet connection to drop whenever the phone rings or is picked up.
Aug 11, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
