Question about Mitsubishi WD-73831 73" HDTV
Mitsubishi TV WD-73831 Light Engine Repair - Mitsubishi WD-73831 73" HDTV
  • 308 Answers
Usually too expensive, scrap the set.
Posted on May 07, 2010
Color wheel for 73
Color wheel is not sold as a part--only the entire optical light engine for the model indicated and it is a small chance it will cause this kind of problem----possible but not likely.
Oct 25, 2012 | Mitsubishi WD-73831 73" HDTV
I have had my Mitsubishi WD 65837 for about 6 months now and I have noticed a white and black dots on the screen. Do you know what causes these and how to fix them?
The tv dam light engine block it is the causes an the problems.This a major design flaw in the tv light engine block by the tv Corporations Samsung,Mitsubishi have this problems more than the other big screen tvs brands.A brand new tv?Take ur warrenty repair quickly,this things wouldn't stops.The white and black dots will continue and keep comming more and more.Until the tv have replace the light engine block or have it replaced another cuircuit board that help the light engine block too work.
Aug 27, 2011 | Mitsubishi WD 65837 65 in. HDTV
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
No picture
I suspect to look and see if the lamp is firing first. If it is not firing then suspect that first. Also some models suffer from faulty capacitors on the digital board that will require the help from a television technician.
Apr 13, 2010 | Mitsubishi WD-73831 73" HDTV
Where can i buy a color wheel for a mitsubishi wd-73831
The color wheel from Mitsubishi PN# 938P030010 is the part that you are looking for.
But I could not find anyone on the internet that can sell you one.
You may try calling Mits, but they are going to suggest that you call a local servicer to diagnose your set and you are looking at 350-400.
Sorry I could not be of more help.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Mar 12, 2010 | Mitsubishi WD-73831 73" HDTV
How do I reset lamp timer on Mitsubishi DLP TV?
I cant find the solution to reset my lamp hours, I replaced it, unplugged the tv like i was supposed to to. Its not reset. I have a 73" 1080p ...wd 73831 series
Sep 18, 2008 | Mitsubishi Diamond WD-65831 65" Projection...
Mitsubishi wd 57731 1080p
see if there is dust inside blocking it.
Jan 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-73831 73" HDTV Logo
1,304 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
