Question about Craftsman 24 Hp 48" Deck Yard Tractor
Changed battery,filled it with gas. Gas not getting to engine.
  • 755 Answers
Remove fuel line at carb and see if gas flows freely.
If it flows freely and the carb is dry either the float is stuck closed or your electric fuel solenoid is unpowered/broken. The solenoid is under the carb. You can see a wire coming out of it. Unhook the wire and check it for power using a test light. If the light turns on with the key on you can remove the fuel bowl and solenoid and test the solenoid and inspect the float for free movement.
Also, make sure your fuel filter is clean and your inline fuel valve wasnt closed accidentally!
Posted on May 11, 2010
Why am i getting gas in crankcase?
You have a stuck float in the carb...the newer carbs a have a small valve that stops the gas from leaking to the ground when stuck..however it now goes into the intake and into the cylinder and open valves and eventual filling the engine with gas oil nix..I had this and found out don't mess with the carb..cause it will happen again..there is a quick and permanent fix..if your tractor has a gas shut it off if not apply one...first if you have gas in oil it must be takin care of now..it can and will fill the entire engine block..so here is the fix..drain the engine block change the filter then remove and ckean the plug..now tape or cover the plug..and slowly crank the engine to blow excess gas from the cylinder. Just keep the plug away..put oil,filter and plugs back..put on a gas shut off or if you already have one..keep it closed at all times when not in operation..here is the important part..when done mowing put the throttle in low and reach up and shut off the gas..let it run unti it uses up the gas left in the carb..when starting open the shut off and let open a few seconds to fill the carb..then start....you must do this eah time you shut it down and restart....or get the carb rebuilt not to say it won't happen again..your choice..good luck.
Jul 01, 2014 | Honda Garden
I have a 2003 Ninja 636 that has been sitting for 3 years. I just changed the battery and added new gas to the old gas that has been in the tank for the last 3 years. It still wont start. Any trouble...
Sheeesh 3yr old gas is'nt gas any more, drain the tank and fill with 93 octane add injector cleaner. change spark plugs. Be prepared to charge battery. Good luck!
Aug 16, 2011 | 2004 kawasaki ZX-6RR
Engine oil appears to be discharging through the air breather. Came on all of the sudden and seems to foul the breather within a short period of time. Rode about 20 miles and stopped within half an hour...
Check your oil level . If it is too high smell the oil to see if it is fouled with gas. If your carb needle sticks the carb may over flow filling the engine. When the engine is too full the breather blows the oil and gas into the air box. Another way to get gas in the oil is if the fuel petcock malfunctions and pours gas into the intake manifold. If the diaphragm of a vacuum petcock gets a hole in it , the engine may flood with gas. The gas flows into motor and past the rings. If you look under the engine in front of the rear wheel you may see a tube with a plug in it. Place a pan under the tube and pull the plug. It is a pollution tube for emptying the crud out of the bottom of the air box. Some Honda's used to fill there engines with gas randomly. If it happened you just changed the oil & air filter, and kept on driving. It just happened for no logical reason. So check your petcock and carbs for problems, change your oil and air filter, and always turn your petcock off when not riding.
Aug 29, 2010 | kawasaki VN 2000 Classic LT Motorcycles
Engine check light comes on and stays on for awhile then goes off. Dometimes when I fill the gas tank the check engine light comes on. is something to do with the gas cap or the instrument lights.
IF IT COME ON EVERY TIME YOU GET GAS.GAS CAP HAS BAD SEAL IT MORE LIKELY YOUR PROBLEM BUT LET AUTO ZONE SCAN IT FREE TO SEE WHAT TROUBLE CODE YOU ARE GETTING.
May 23, 2010 | 2003 Pontiac Bonneville
My truck started running rough now it won't stay running
THE GAS IS PROBABLY GOT WATER IN IT.YOU NEED FILL UP GAS TANK WITH GOOD GAS AND ADD GAS TREATMENT TO EAT UP THE WATER IN GAS TANK.
Jan 08, 2010 | 2000 GMC New Sierra 1500
My car stalled and it will turn over but will run rough for a minute and then die. Does not seem to be getting enough gas to keep running. I have a half a tank of gas. It is a 1995 Toyota Camry 4 cyl...
there are many reasons for this...it could be a stopped up fuel filter, to dirty injectors. I would change the fuel filter, then fill the tank, and add fuel injector cleaner, The gas we get these days is not what it used to be....try changing where you get your gas....hope this helps, and please rate me...thank you
Jan 31, 2009 | 1995 Toyota Camry
Fuel delivery problem upon start-up
hello, when did this problem start, right after a fill up, after sitting all night after a fill up or something to that effect. Please give more info
Jan 17, 2009 | 1994 Dodge Spirit
Fill up with gas
i had the same problem, you have to change the perge control valve, its on the back of the engine below where the plastic intake pipe meets the metal intake manifold on the back side of the engine between the engine block and the firewall, on the underside of your car hood you will see a vacume system diagram, it will illistrate where the valve is, it should cost about 30 bucks or so at a hyundai dealership
Oct 13, 2008 | 2001 Hyundai Elantra
Craftsman 24 Hp 48" Deck Yard Tractor Logo
159 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
