Question about Yamaha GO46 Sound Card
Yamaha GO46 is not recognized as an audio device - wdm driver not instaled properly
I installed my GO46 in a Intel dual core 2.0, and it doesn`t assume it as an audio device. It appears as a firewire device, but the WMD drivers doesn,t make the device work....i have tried everything with the instalation, even format the computer because i thougt it was conflit with the creative sound blaster drivers, but it still don`t work.
At the first time it seems to be software, but now i think it may be of the product.
Anyone knows why this product was discontinued by yamaha?
  • 5 more comments
  • krellmann Apr 01, 2008
    I have a simular problem with the go46. it seems like the problem
    occured over night. the day before everything was fine. the next day after a finished a recording it wasn't possible to play audio-files. absolutly no sound. it's still possible to route an spdif signal to the outputs, though. When I unplug and replug the firewire cabel everything seems normal again for a while. audio files will play for a few seconds and then .... silence again. Unfortunatly I can't check the device on my notebook as it won't be recognized on the 4-Pin connector (another annoying problem). So my assumption was also that it's has something to do with IRQ Sharing. It might be possible that the system changed some IRQ Settings at one time. I use Windows XP SP2. I uninstalled all PCI Cards of my computer including the RME9632 and a network card but don't help either. I just don't have any further ideas anymore and I already assume that the interface is damaged. Maybe it's the firmware and an update of it would help but I don't know where to get the software. I didn't find anything on the yamaha site. So if anyone has any other ideas please let me know.
  • mutiger Oct 02, 2008
    I have the same issue with my GO46 on Vista 64.  It works fine on Mac Leopard though, so I know there's nothing wrong with the hardware.  Thank goodness I'm NOT a PC (jab at MS's stupid commercials).
  • Thiago Santos
    Thiago Santos Oct 25, 2008
    I have exactly the same problem. My Yamaha GO46 just stopped being recognized by the computer one day. The same behaviour is happens with my desktop and notebook, so it seams to be something with the audio card.
    I tried to reinstall the driver (v1.00 - for XP - downloaded today from yamaha web site) and now, when the installer ask to connect the audio card to the PC, the card is not recognized anymore, in both computers.
    I tried to change the IRG sharing configurantions, and disable the audio device as your suggestion, but I could not find anything related to audio cards or to the IEEE 1394 on my BIOS. My motherboard is a ASUS P5BDeluxe.
    It is amazing how few information one find on the internet regarding GO46 troubleshooting.
    To make it worse, I am from Brazil and, considering that this audio card is not selled here, the company "Yamaha Brasil" is telling that this product is not supported by their local authorized technicians.
    So, anything you could helpme will be very useful.
    Many thanks,
    Thiago Santos
  • Thiago Santos
    I finally found the IEEE 1394 and HD Audio Controller on my computer BIOS, and tried to disabled /re-enable them in alternated configuration, without sucess. I could verify the "Texas Instruments OHCI Compliant IEEE 1394 Host Controller", coming and going from the device manger,as I enabeld/diabled on the BIOS, but I cant change any IRQ setgins.
    Tried to update the driver through windows update, but it says that my version is the most recent.
    So, I run out off alternatives. I will keep trying to speek with someone from Yamaha here.
    If anyone have any sugestion or a similar issue, I will be very happy to hear!
    Thanks a lot.
    Thiago Santos
  • Thiago Santos
    Thiago Santos Oct 31, 2008
    I spoke with Yamaha Brasil and they are now starting to support GO46 in Brasil, so I will be the first support case.
    Thanks.
    Thiago
  • shlomo_liron Nov 02, 2008
    i have the same problem! i think it's a problem with the devise.
    it dosn't work on my vista 32 laptop and on my XP pc...
  • Thiago Santos
    Thiago Santos Nov 04, 2008
    Yamaha officilly told me that my GO46 is dead. It has a damage on the firewire circuit, caused probably by a voltage peak, that cannot be fixed.
    What is strange is that I have a stabilizer and my desktop did not present any other problem, but, I have no choice than use it as a very expensive paperweight.
    So, I am wondering - if in other audio interfaces have the same problem, the damage should not be fixable??
    Cheers,
    Thiago Santos
Get a new soundcard GO46 is a bag of trouble. I had to get a special Firewire Card with a Texas Instrument chip, since the cheap internal firewire interfaces don't work with this card. Also make sure you are not running XP64, since it is not supported. good luck
Posted on Jul 20, 2010
Install the yamaha driver from yamahasynth.com. I used the newer vista driver on xp and it works. Then install these two patches: WindowsXP-KB885222-v2-x86-ENU.exe, WindowsXP-KB896256-v4-x86-ENU.exe (ENU is for english Windows). If you have sp 1 all should work without patches (I don't so it's somebody elses theory.) If you have sp 2 these two patches installed after the yamaha driver = works. If you have sp 3 your in for some silly **** because windows recognizes these patches as obsolete and doesn't install automatically. At that point you could try looking at RME page for a work-around, and I think that Mackie provides a similar solution for an onyx mixer. Google if you want to, install sp 1 or 2 if you must.
And oh: DON'T PANIC.
Cheers,
MASAD
PS. That guy with the first answer is silly, to say the least.
Posted on Mar 30, 2009
I have tried all solutions in windows 7. no go. if I plug it into the Intel mac OSX 2ish firewire port, BINGO, no problems, runs like a dream. Go figure.
Posted on Apr 17, 2011
  • 68 Answers
  1. It may be hardware problem (IRQ sharing problem). First go to PC's bios setting and disable "Audio Device" by searching options. Try to change sound card with other Pci slot (white slot).
  2. To get it's latest driver, get free register on www.driverguide.com and after signing in type "yamaha GO46" in search bar on this site. Don't forget to vote me. Thanks
Posted on Mar 28, 2008
Driver audio HP compaq presario SR5350F pc Intel pentium dual core
You can download the audio and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 25, 2013 | HP Compaq Presario SR5350F Desktop PC...
My skype sound doesn't work
Please click this Check Your Audio and Video Devices to test your audio/video.
Do you have the correct audio devices selected? Did the test work?
After doing the above. Click this link to call the Skype test call echo 123:Click Here You should hear the voice and your recorded voice as well, if everything is ok.
Addtionally, are you on the most current release? If not install over what you have by clicking the "Windows 5.8" link below as well. You can do the above tests again after upgrading as well if needed.
Auto Accessories
May 24, 2012 | Dell OptiPlex 380 MT Desktop Computer...
Realtek Audio driver Installation failure on DG PR31
First uninstall driver and software from add remove program. Then install chipset driver>>then run sound driver setup>>when it will ask for driver search click cancel after the installation process restart computer.
Sep 20, 2009 | Intel DG31PR Motherboard
No Audio
Here is the link to the page for the driver for your audio. once you install this you should be up and running again. Hope this helps!!
Jun 28, 2009 | Intel Computers & Internet
Problem in audio driver for dg31pr
Visit this link: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839, select your OS and download the latest sound driver. Also run your add hardware from control panel even if you have to select the device manually.........sodeep
Jun 12, 2009 | Intel DG31PR Motherboard
Installation failed
Hi sunil27482, please create a folder on you're desktop & name it sound. Go to this Intel link & download driver number 3 into the sound folder.
Audio: Intel® HD Audio Controller - Realtek* Codec 4/29/2008
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Once downloaded into the sound folder uncompress the driver software by double left clicking on the .exe file. You will now see a new folder named "AUD_allOS_5605_PV_Realtek".
Now go back into device manager &
Right click once on the yellow ! point & left click once on update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find you're desktop & open the sound folder you created. Click once on the AUD_allOS_5605_PV_Realtek folder so it is high lighted. Than click OK. Windows will find the correct driver software & install it.
If you have any trouble, please list here the issue.
Good Luck!
Mike
Jul 04, 2008 | Intel DG31PR Motherboard
Audio device is not working
I have been working on this for months and finally got everything including front audio panel going. First Download the latest realtek audio drivers available  from intel's website or go here and download #3 http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows%2A+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21. Next goto control panel and add/remove programs then look for realtek audio drivers that have been previously installed. Remove program if one is found. Then go to device manager (right click my computer, go to properties, Then hardware, then device manager. Click on the"+" in front of system devices. Find "microsoft uaa bus driver for high defintion audio". Right click that and select, "disable". Then right click it again and "unintstall" the device. This will allow you to install the audio drivers on your disc, or ones you have downloaded to install without an error message. Once done install your audio drivers and restart your PC and windows should start dectecting your new hardware. An installation wizzard pops up. Install the files needed yourself from a specific location, not a disk. It will ask for location of file name "hdaudbus.sys". That file is in C:/Windows/System32 folder. If it's not there, which it should be, just find and download that one file but it should already be there. I have done all this on xp home ed, sp3. I now have sound, and my front audio panel works. Please let me know if you have any problems by emailing me at chadmon10@hotmail.com
Jun 22, 2008 | Intel DG31PR Motherboard
Powerbook doesn't recognize Yamaha GO46 FW interface
Hello. I had the same problem and solved by mere casuality. If you disconnect the AC power adaptor and let the Firewire connection to be the only power supplier, then the GO46 will be inmediately recognised by the "Preferences -> Sound" panel of the G4.
Hope I've been helpful. Bye.
Oct 27, 2007 | Yamaha GO46 Sound Card
Audio driver installation failed from mother board cd
The most common solution was this: open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio" uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.) D.W. install realtek driver the realtek driver includes the UAA driver too.Hope this helps.
Aug 29, 2007 | E-Mu 0404 Sound Card
Yamaha GO46 Sound Card Logo
1,945 people viewed this question
Top Yamaha Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Carlos L. Burgos
Carlos L. Burgos
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
