Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
PRINTER SHUT DOWN INK CARTRIDGE WILL NOW MOVE SO I CAN REPLACE IT I HAVE ALREADY UNPLUGGED THE POWER FROM THE PRINTER AND REPLUGGED IT IN
    Brigadier General:
  • 10,406 Answers
> cartidge will now move
If you mean will NOT move ...
Turn the printer on.
Open the cover over the ink-cartridges.
The carrier should slide to a position where the cartridges can be removed.
If it does not slide, then the belt that pulls the carrier is broken, or it's no longer connected to the carrier.
If all else fails, replace the printer -- try to find one that uses your existing ink-cartridges.
Posted on May 07, 2010
Can't get WF-3520 cartridge holder box from far right position so I can remove & replace an ink cartridge
To force cartridge removal do the following
Shut down the printer (if it is powered on)
Now turn the printer on
When you see that the carriage starts to move instantly unplug the printer power cable
Now you can move the carriage freely by hand!
Move it in the cartridge change position and change the cartridge you want to change
Do it just if the printer has a defective cartridge and the carriage won't go to the cartridge change position :)
Hope you found it useful!
Dec 17, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Error "ink system failure", shut off printer, unplugged, replugged and attempted to turn on, will not turn on.
Follow this link to get help:-http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&lc=en&cc=us&dlc=en&product=439491
Oct 01, 2012 | HP PhotoSmart Office Equipment & Supplies
Orange ink light blinks, printer will not print. Turned off, shut down computer, unplugged everything & replugged & restarted but did not fix problem.
Open the printer ink cartridge bay, and remove and re-insert the cartridge, it may be empty and need to be replaced.
Feb 28, 2011 | HP DeskJet 932c InkJet Printer
Left ink cartridge incorrect. It is the right ink
A trick which may work is cleaning the contacts on both the cartridge and the printer.
Make sure you've switched it off first, I'd try gently buffing with a soft dry cloth first.
HP reccommend using distilled water and cotton buds, but not alcohol based cleaning fluids.
Allow the water to evaporate before replacing cartridge and switching on.
May 11, 2010 | Dell 946 All-In-One InkJet Printer
We had a cartridge error. We refilled and replaced the cartridges but still have a cartridge error. We have restarted and unplugged and replugged the printer a couple of times and still have the cartridge...
Your cartridge has something wrong with its electronics. There is no way to "fix" this problem. The reason you could print a calibration sheet is because the printer does not need an electrically functioning cartridge to print this test page. You need to purchase an ink cartridge that has good electronics on it. It doesn't matter if you get a refill or original manufacturer cartridge.
Oct 02, 2009 | HP PSC 1410 All-In-One InkJet Printer
Canon multipass C555 will not recognize new cartridge
their may be dryed out ink in the jets. check for that.
Sep 10, 2009 | Canon MultiPASS C555 InkJet Printer
Grinding noise in cartridge for hp laserjet 1200 series printer. I replced cartridge and still hear noise sometime worse and then not so loud.
I have the same problem and I know what is causing my problem. It's not in the cartridge. You're laser scanner is going to go bad. I had the problem 3 months ago. I would only make the grinding noise when it powered up. Printing was okay. I don't use the printer that much. Then about a week ago I notice only the bottom diagnostic light was on. I unplug the power and powered it back up. The grinding noise got louder and wouldn't stop. I unplugged the printer an replugged. Same thing.
I was bored (christmas day) and decided to open my printer to see what the root cause problem was. I removed several screws and once I got all the printer naked (removed all the plastic outside). I plugged it in an tried to listen where the problem was. I notice a vibration at the laser scanner (top black piece). I unplugged the printer. I unplugged the power source to the laser scanner. Replugged the power and saw all the gears move with no noise. Powered off. Replugged laser scanner. Powered on. Noise back. Defective laser scanner. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps.
Nov 26, 2008 | HP LaserJet 1200 Printer
Don't know how to move the cartridges to replace the ink.
Please follow the instructions below to ensure correct installation:
  1. Lower the printer's output tray and open the top cover.
  2. Connect the power cable to the printer.
And switch on the printer.
The print heads will now move to the replacement position. If they do not move to a change position press the Red ink button on the printer.
  • Lift up the ink cartridge clamps.
    Before you open the new ink cartridge package, shake it four or five times. Then remove it from the package.
    Do not touch the green chip
    on the side of the cartridge. This can damage the ink cartridge.
    Remove the yellow tape from the bottom of the ink cartridge.
    You must remove the yellow tape from the cartridge before installing it; otherwise, print quality may decline or you may not be able to print.
    If you have installed an ink cartridge without removing the yellow tape, take the cartridge out of the product remove the yellow tape, and then reinstall it.
    Do not remove the transparent seal from the bottom of the cartridge or the label on the cartridge; otherwise the cartridge may become unusable or ink will leak.
    Place the ink cartridge into the cartridge holder with the bottom down. Then push down the ink cartridge until it clicks into place.
    Repeat steps 4 to 6 for each ink cartridge.
  • Close the ink cartridge cover and press it until it clicks into place
      If you find it difficult to close the cartridge cover, make sure all the cartridges are firmly seated. Press down on each cartridge until you hear it click into place. Do not attempt to force the cover closed.
    1. Close the printer cover and press the ink or start button to begin charging the system. Charging can take up to three minutes and is complete when the power light stops flashing.
    While the ink system is charging do not switch off the printer.
    Sep 16, 2008 | Epson Stylus 880 InkJet Color Printer
    Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
