Panasonic tv 28PW6515 - sound cuts out
Recently I've started to have a problem with the tv whereby after anhour or so of it being on the sound goes down automatically withoutanyone touching it or the remotes. The red light flickers as the soundgoes down until the sound cuts out totally.
I would be very grateful if you could let me know what to do about this probelm. Many thanks Lucy
    Top Expert:
  • Televison & ... Master
  • 76,140 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Posted on Sep 03, 2017
SOURCE:
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
hi there, have the same kind of problem twice so far after was bought for me as x-mas present (although my viera isnt plasma, its an LCD TX-32LMD70A)..
I Pulled out the mains plug for about 10-20 seconds and then plugged back in (power button at top was pushed in, in the on position, so when the power was on, the tv just goes straight on). It then worked.
i would however like to know why this happens ( i really hope this isnt a hardware problem, as like many others... its only months old!!)
hope this helps
Posted on Apr 27, 2008
SOURCE: THOMSON SCENIUM 44RW65US Red light flickers
i have the same problem. i have to switch it off at the mains 5 times b4 it comes on
Posted on Jun 08, 2008
SOURCE: PANASONIC PLASMA TH42PZ700U --NO PICTURE NO SOUND
Call Panasonic customer service. This is a well-known problem (I had the exact same problem with my television) and Panasonic will send over a technician to fix your television. I needed two new parts to be installed. Once the new parts are installed your tv should work fine (although now my volume doesn't work).
Posted on Jul 01, 2008
  • 2337 Answers
SOURCE: TV won't turn on!
The failure on these LCDs is mostly with a defective power supply. It appears like the voltage is not enough to make it work.
I repair these power supplies, let me know if you require further assistance. You can also write to [email protected] for more info.
Posted on Oct 17, 2008
SOURCE: Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
Posted on Sep 11, 2009
No sound from DVP-SR760H
https://www.sony.co.uk/electronics/support/home-video-dvd-players.../dvp-sr760hp
This is the manual whereby you can review the many functions of the player.
HDMI being a Complete communication system connects all of the vital components at one time, using one cable format. Thus unless you have a bad cable, the only other issue could be the Player or TV itself. Turn the cable around or try another cable to start with.
Jan 14, 2018 | Televison & Video
I need a Panasonic TV TH-42PD25 base stand! I've searched ebay, no luck. This might sound dumb, but can I use base stands from any of the other Panasonic 42" models?
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
Nov 30, 2012 | Televison & Video
Philips 28pw6515/05
Good old cash generator, make one wonder why they are there in the first place doesn't it.
Sep 16, 2017 | Philips 28PW6506 28" TV
Jun 29, 2008 | Televison & Video
Panasonic SC-PT850w sound cuts out
Are you watching 10HD off the air from an antenna? You are losing video and audio intermittently, which may just be indicative of a weak signal. Does your TV have a signal meter?
Apr 27, 2008 | Panasonic Home Theater System System
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Sep 19, 2006 | Philips 28PW6506 28" TV
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
Ekse
