Question about Siemens WFXD5200UC Front Load Washer
Rubber door seal has problems with algae - Siemens WFXD5200UC Front Load Washer
  • Siemens Master
  • 744 Answers
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 31, 2013
    Top Expert:
  • Siemens Master
  • 76,164 Answers
There is littrle u can do about this except clean it with bleach on a regular basis, also make sure the drain at the bottom of the seal is clear.
Posted on May 07, 2010
3 Suggested Answers
SOURCE: replacing door seal rubber boot
Hi its just a peice of wire with a spring tensioner just pull the door seal free" towards side of machine not forward" it will come .....then you will see wire ! you will kick yourself when you see.... it i did lol
Tommy-B-
Posted on Nov 02, 2008
aardvarkrepr
  • 62 Answers
SOURCE: Rubber door seal problem
In my 13.5 years experience I have never experienced a door seal coming away from the drum!!!
If this was the case then you would have a major water leak!!!
Does the door seal look twisted at all?
Have a good look at the seal. Is there any black mold on the seal?
If the seal has come off then I would need to guide you through the refit process.
Please email me on: aardvark.repairs@btinternet.com and I will email you back my phone number
Regards
Aardvark Repairs
Posted on Nov 17, 2009
MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8 CU FT UPRIGHT FREEZER MCUF88W -- BRAND NEW JUST BOUGHT?? HELP
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
Sep 27, 2010 | Magic Chef 11.8 cu. ft. / 334 liter...
Leak in rear lifthatch water leaking into rear storage area. It appears to be getting in under the rubber gasket door seal
Hi this is quite a common problem, you have a couple of options you can either go out and buy a new door rubber seal or if it one of those seals where you can get you hand in between two parts of the seal then what you can do is get some thick string and run this in the middle of the seal doing this will pack the seal out a bit and then when the door is shut this will make a lot better seal and it will then stop the water getting in.
let me know if you need further assistance ok
ps the rubber seal isnt to expensive to buy but even a new rubber may still have the same problem as its more to do with the way the door is fitted and it seems it dont push the seal hard enough to prevent water getting in so i have found packing it out with some thick string or twine will push the seal out more and will seal it properly when you shut the door to
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 31, 2010 | 2007 Chevrolet Equinox LS New Cars
Regards
Aardvark Repairs
Nov 17, 2009 | Washing Machines
Water leaking from door
This video will show you how to change a door seal on this Bosch front loader washing machine to stop leak
we have all bosch repairs in our channel
You can get seals on eBay
Aug 29, 2009 | Bosch Washing Machines
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Is there a way to clean rubber seal around the opening?
Use a vinagar solution to clean the rubber seal. bleach will damage the rubber.
Apr 29, 2009 | Washing Machines
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Rubber Seal not Sealing
This seems to be a common problem with front loaders, but there is an easy fix if you follow these simple steps:
1. The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first.
2. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions.
3. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this.
 Good luck and I hope this helps you.
Oct 24, 2007 | Kenmore Elite 45986 Front Load Washer
Siemens WFXD5200UC Front Load Washer Logo
340 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
