Question about Lands Phones
I have a SAGEM D86c hands free house phone. The handset appears to have disconnected from the base and I can't use the phone. I have lost the instruction book. Do you know how I can fix this problem?
  • yvettelee Aug 21, 2008
    i have switched my sagem d86c handset off now it wont switch on again
Http://www.sagem.com/support/site/livret/UM_D86C_UK.pdf
there is the manual. My handset has unregistered itself as well and I can't seem to get it to talk to teh base station :S
Posted on Sep 07, 2008
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
1.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
SYSTEM RESET menu.
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
2.
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
3.
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
SYSTEM RESET menu.
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
Base appears to be shorted for phone connection. When I first hook phone line up I have a dial tone, but when I press stop on any handset or speaker phone the phone will not disconnect. The line eventually...
I have same problem but it will happen while I am in middle of talking. handset will go dead and say it is not connecting to base, but base indicates line is in use. I try it with other handsets to no avail
Apr 13, 2011 | Panasonic KX-TG9341T Cordless Phone
I have purchased a SL82318 Handset. I have a SL82318 system, with all three original handsets working perfectly. This fourth handset displays: "Connecting..." and nothing else. According to...
*331734#Menu Select on the handset should de-register that handset from the old base, then you can register it to the base as per the manual (put it in the base and hold down the handset locator button for 4 seconds)
Jan 04, 2011 | Vtech SL80108 1.9 GHz 1-Line Cordless...
Voxtel infinity x1 cordless phone is locked
Please press on red cancell button for 2 seconds, the phone will unlock.
Dec 13, 2008 | Uniden Cordless Phone
Uniden Power Max 5.8 - (TRU8880-2)
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
please rate this post
Aug 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
Hi you posted that you could unlock any sagem! can you unlock sagem my150x and will it be free?
hi,i am sarab from india .i have sagem my150x handset but my handset is not working .my handset is locked so,i canot use it pls ,tell me about the soloution of this problem .i'm very thankfull to u for this pls .....help me
my id is sarbsaab@yahoo.com
Jun 02, 2008 | Sagem My501X Cellular Phone
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Uniden TRU9488 Phone
OU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Jan 28, 2008 | Uniden TRU9488 Phone
Lands Phones Logo
303 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
