Question about SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400
Where did all my disc space go?
I have erased my previous back-ups on my Firewire FireLite external hard drive, but it's saying there is essentially very little disk space available. How can I get the drive reprogrammed or somehow reverted to its original configuration?
    Brigadier General:
  • 10,406 Answers
Empty your "Recycle Bin" -- it's possible that the files have just "moved" from their original location, and have _not_ really been "deleted".
Or, right-mouse click on "My Computer", and choose "Manage". Click through "Disk Management (local)", and you'll be able to "delete" the partition(s) on the drive, and then "create" a "new" partition, which, of course, will be 100% "empty".
Posted on May 07, 2010
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
Erase Firelite backups so drive is clean and I can start over
Empty the Recycle Bin -- the files that you "erased" were _only_ moved from their location into the Recycle Bin -- they still occupy just as much disk-space.
Jan 29, 2010 | SmartDisk FireLite 40 GB Hard Drive
I'm having problems connecting FireLite portable hard drives to my mc.
1. Check operating system version sometimes its just the version not all mac versions like externals.
2. Under disk manager if the drive does not appear 9 times out of 10 its not compatable with the os your using.
Thanks
Sep 17, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Miising power supply
It takes a 5V adapter
Here is the part number
C14627 - AC ADAPTER FOR USB BUS-POWERED FIRELITE - ACFLB
Hope this helps!
Feb 27, 2009 | SmartDisk 40GB - 4200rpm - 40MBps - IEEE...
My SmartDisk 80 gb FireLite hard drive says it is full but it is empty. What could be the reason for this and how would I format it? I use a Macbook pro. I dont want to have to buy a new external...
You will receive an error message when copying a file larger than 4GB to the hard drive if the drive is formatted FAT32. The FAT32 file system has a file size limitation of 4GB. You may also receive an error when backing up to the hard drive using backup software. To correct this problem you will need to format the drive to NTFS. If you are using Windows ME or 98SE, you will not be able to use NTFS.
There are some products that do not support the NTFS files system or changing their file system. If you own a FlashTrax/FlashTrax XT/FotoChute/PhotoBank/USB FireLite XPress, you cannot change the format of the drive to NTFS. It must be kept as FAT32 in order to operate properly. If you are using SOHO NAS via ethernet, do not format it to NTFS. If you have any questions, please contact technical support before you format the drive.
Warning: Formatting a hard drive erases all data from the drive. Please backup any data prior to formatting the hard drive.
To format to NTFS, open My Computer.
1.Right-click on the Verbatim hard drive, left-click on Format.
2.Select NTFS as the File System.
3.Place a check in Quick Format.
4.Click Start.
Once the format completes, you will be able to copy files larger than 4GB to the hard drive.
Feb 03, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
Firelite 60gb external hd
to clear all the unused data from your computer you need to do to things Disk defrag and Disk cleanup located
Programs> Accessories> System Tools if this is a externul drive with no Os on it Rigth click on the device icon select Format this will to erase Data bypassing your desk top bin
Jun 24, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Formatted hard disk on pc now it won't run on mac
Try plugging your hard drive into your mac, open "Disk Utility" select your hard drive in the list on the side, Click RAID, change the Volume Format to MS-DOS (FAT), and it should work.
Hope this helps!
Apr 03, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
40 GIG EXTERNAL
Are you familiar with hidden files and/or using the Terminal application? Hidden files could be the cause of your disk usage and you could use Terminal to verify and remove the files. The easiest way to erase the drive and restore the space, though, is to use Disk Utility and erase the partition. Open Disk Utility Select the Volume name Click the Erase tab Click the Erase button BE SURE YOU HAVE NOTHING ON THE DRIVE THAT YOU WANT! Please let me know if this helps or if you have more questions.
Aug 22, 2007 | FireLite (USBFLB80) Hard Drive
Open Questions:
SmartDisk 160GB FIRELITE PORTABLE FIREWIRE HARD DRIVE 5400 RPM 2.5IN 160 GB FireWire 400 Logo
112 people viewed this question
Top SmartDisk Computers & Internet Experts
 Ian Kayhan
Ian Kayhan
terminalcon
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
