Question about Bosch HBN 730520B / 730560B Electric Single Oven
Bulb blown and now fan is not working
The bulb blown and i replaced it but now the fan wont work but every other setting does
  • 269 Answers
When you changed the bulb did you turn the power off at the mains if so then you need to reset the clock on the front panel the fan will not work but all other functions will look in book it will tell you clock reset.Hope I helped.
Good Luck.
Posted on May 07, 2010
Replaced fuse and blown bulb,grill works as does the fan but the oven does not ignite.
You don't give make/model/year etc but can you light the oven manually with a taper?
Did you have an owners book with it?
I take it the igniter works the top burners?
Feb 16, 2016 | Ovens
Neff b1861 oven fan and interior lights not working on Circotherm settings
sounds like the control switch to me. if you have already taken it apart it's the switch with the most wiring.
Mar 21, 2014 | Ovens
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
My fan forced setting is not working, it is blowing cool air only, all other settings are working fine
There is an element surrounding the fan that may have blown. Removed the fan cover and inspect the element for damage, sometimes you cannot see any damage, but it may still be faulty. Oven needs to be removed from the wall to inspect the wiring to the elememt or replace it. Ensurre th ewall switch is off before starting any work on any oven.
Sep 11, 2011 | Ovens
The lights on the under side of the rangehood do not work .i have replace the bulbs ,the exhaust fan works ,is their a re set switch
could be a blown transformer to supply the correct power to the lights or a loose connection on the light holders.
Aug 23, 2010 | Ovens
Neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Neff B1861 Single circotherm super...
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
Bosch HBN 730520B / 730560B Electric Single Oven Logo
293 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
