Question about Kenmore 63942 Dryer
Hi...I have a Kenmore Gas Dryer (110.74642400)...I had a repair man come to fix and replaced the thermal fuse...however, it is not working again. It worked for about 3 weeks after he replaced it...at that time he said that I may want to have a new vent system put in because my dryer was not venting properly. I used the "fixed" dryer with the old vent for 3 weeks until it blew again. I had my vent replaced and started using my dryer again. It worked for about 10 minutes then went cool, and it no longer heats up. Could the fuse have blown in just that short 3 week time frame when I still had the bad vent? Or could there be another problem with my dryer? Thanks in advance!!!
  • 1 more comment
  • Aimee Geisel
    Aimee Geisel May 10, 2010
    Thanks for your help...however replacing the thermal fuse did not work. The dryer will heat up for the first part of the cycle but will not stay hot the whole cycle. Any other ideas at to what it could be? Thanks again!
  • Aimee Geisel
    Aimee Geisel May 15, 2010
    Thanks! I'm going to attempt to replace them today...do I need to unhook the gas to do so?
  • Aimee Geisel
    How do I get to the gas coils? I removed 2 screws on the front of the dryer but the front panel will not come off.
  • Kenmore Master
  • 2,333 Answers
If he changed the thermal fuse he should have cleaned out the dryer and vent line for you because it's just gonna pop again and again until the dryer gets cleaned out.you need to unplug the dryer,pull it out and remove the vent line and the back panel,on the left side there's a duct that the lint filter slides into,pull out the filter and remove the two phillips screws in front of the filter on the top panel,go in the back and take out the four screws that hold the duct in place,remove it and clean it out,vac out any lint in the back of dryer,put the duct back on.to the left of the duct and around four inches up you'll see a white thermal fuse part number 3392519,pull one of the wires off and check it with a meter,if it's bad change it out.next,if the vent line is long i use a leaf blower to blow out the line,you could have a birds nest in there or the lint just could have built up,make sure the outside vent is open with nothing blocking it,any screens or cages remove them all they do is catch lint.put the back panel on and the cleaned out vent line and put it back into place,don't put back the two phillips screws yet,next with a screw driver pop the top panel up,stick the screw driver in between the front and top panel around two inches in from the sides of dryer and pop up the top,next remove the two 5/16 inch screws one on each side of front panel and unplug the wiring harness in the top right side,you might have to stick a small screw driver in between the plastic to separate the plug,then pull up on both sides of front panel to remove it and vac out the inside of dryer.put it back together and you should have no more problems,let me know how you make out
Posted on May 07, 2010
  • 21 more comments
  • Sal DeAngelo May 10, 2010
    you have bad gas coils,it's just a freaky thing that the coils failed right after you fixed the fuse.when the coils are on there way out they'll run for the first 15 to 30 minutes and when they heat up they fail so you'll have parcial heat and the clothes will fell a little warm.the coils are located on top of the gas valve in the front of dryer,remove the two phillips screws,remove the coil cover and replace the two coils,it's simple to do,unplug the dryer first to be safe,let me know how you make out and next time check the part you think it is with a meter so you don't buy parts you don't need,i thought you knew it was the fuse by the way you discribed the problem
    part number 12001349 gas coils
  • Sal DeAngelo May 11, 2010
    if it's heating at first and then no heat you have bad gas coils,they are located on top of the gas valve,very easy to change,take out the two phillips screws and remove the top cover and change out the coils
    you have bad gas coils if it gets hot for the first 15 to 30 minutes,easy to change out,remove the two phillips screws and remove the cover and change out the coils,they are located on top of the gas valve in the front of dryer,i wrote back to you a couple of times but for some reason it won't send to you,also next time before you change out a part check it with a meter and always remove at least one of the wires on the part you're checking and make sure the dryer is unplugged,
    you have bad gas coils,they are located on top of the gas valve,very easy to change,remove the two phillips screws take off the cover and change out the coils,next time get a meter and check the part you think is bad so you don't change out parts that are still good,remove at least one of the wires on the part you're checking and unplug the dryer,i tried writing to you but it wouldn't post it i don't know what's up with the site,let me know how you make out
  • Sal DeAngelo May 12, 2010
    if it's hot at the start and then no heat after 15 to 30 minutes you have bad gas coils
    it sounds like you have bad gas coils if it heats for the first 15 to 30 minutes then no heat
    the gas coils are bad and need to be changed out
    bad gas coils
    bad gas coils
    bad gas coils
    bad gas coils
    bad gas coils
    you need to change out the gas coils
    i'm sorry that there are so many answers there,i've been trying to answer you for days but it wouldn't post what i was writing and as you can see i kept at it ha,if i can help you again let me know and i hope your dryer is fixed
  • Sal DeAngelo May 15, 2010
    unplug the dryer,remove the two phillips screws in front of the filter on the top panel.get a screw driver and stick it between the top and front panel around two inches from both sides,do one side at a time,there's a clip in there that holds the panels together,one on each side,once you have the top popped you'll see a white wire harness that has to be pulled apart,that's the door switch wires,you might have to stick a screw driver in between the plastic harness to separate it,then remove the two 5/16 inch screws one on each side around three inches down from the top,now pull the front panel up one side at a time and remove the front panel,on the left side you'll see the gas valve with the coils on top.remove the two phillips screws,remove the cover and change out the coils.if you need any more help let me know
    part number 12001349.there's a site on this page where you can order the coils,it says get whirlpool dryer coils,the coils are the same
No heat on gas dryer
follow this steps and fix it. God bless you
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2#ixzz2gWDkLvJt
Oct 01, 2013 | Kenmore 75944 Gas Dryer
I have a Kenmore gas dryer model 110.77670400. The ignitor lights, but gas valve doesn't open. I tested thermal switches in back for continuity and all checked good. Flame sensor is good and I replaced...
Thank you for contacting fixya.com.
If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.However unplug your Kenmore gas dryer from its electrical outlet. Make sure that all electricity has been disconnected from your dryer.
Turn off the gas valve that supplies gas to your Kenmore gas dryer. Remove the gas flex line at the shut-off valve using an adjustable wrench.
Remove your dryer's back panel. Take out the screws on the back of the dryer and the panel will come free. Set the panel and screws aside until you are ready to replace them.
Locate the thermal fuse between the dryer's blower housing and exhaust. The thermal fuse looks like a white plastic strip with two connected wires.
Please get back to us if you have further query else please accept the suggestion.
Jun 15, 2011 | Dryers
Kenmore gas dryer wont heat up
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 11, 2009 | Kenmore 73952 Gas Dryer
Turn on but no heat
A bad thermal fuse will keep the gas valves from opening , therefor , no heat at any time . There will be no orange glow with a bad ignitor (used to lite the burner ) . Bad coils , the ignitor will glow and when the sensor clicks to cut off the ignitor , the coils should open to let the gas thru . Your dryer has a little peep hole you can remove to see the operation of the gas valve . Also , check the thermal fuse again ( or put the 2 wires togather to check) , disconnect the vent hose from the dryer and dry a load to see if dryes correctly .( Make sure you have good air flow at the dryer )The reason for this is because a dirty or clogged vent , not cleaning the lint screen vent hose kinked , or vent clogged from dryer to outside , will cause the thermal fuse to open .
Jul 29, 2009 | Kenmore 74602 Gas Dryer
Kenmore electric dryer heats but does not dry the
Hi, Here are the obvious parts to check: Heater, High limit, Thermal fuse or thermostats...these are all generally located in the back but some models you access them from front. the most common cause is either heater or thermal fuse, I will include a picture of the thermal fuse. If you test these parts and find they all work you may be looking at a centrifiacal switch problem.
Here is a picture of the thermal fuse check this part first:
http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
Please feel free to contact again if you have any other problems.
Hope this helps.
Jun 23, 2009 | Kenmore 63942 Dryer
Hi, I have a Kenmore gas dryer that shows the symptoms above -no heat, but everything is operational-. I have replaced the thermal fuse, and both thermostats. It did work for a few minutes, but then it...
Really? You want me to pay you to tell me how to fix it, but you want me to TELL YOU how I fixed it for free? Some scam you're running. Please remove my e-mail address from your system.
Jun 11, 2009 | Kenmore 72062 Gas Dryer
My kenmore dryer wont heat up
HELLO,IS IT ELECTRIC OR GAS ? IF ITS GAS THEN ITS A THERMAL FUSE LOCATED ON THE INSIDE OF THE HEATER DUCT,IF ITS ELECTRIC THEN IT COULD BE A HEATING ELEMENT BURNT OUT EATHER WAY IT'LL BE A EASY FIX AND WILL ONLY COST THE MONEY FOR THE PART REPLACEMENT AND YOUR TIME
Apr 06, 2009 | Dryers
Dryer
hi Thanks for the question. the problem is with the thermal fuse .located in the dryer at the back. to repair. pull dryer from wall. remove back panel .clean all lint. fuse is located at the air duct. a small plastic piece with 2 blue wires to it. replace this part. thanks the appliance doc
Sep 09, 2008 | Kenmore 73952 Gas Dryer
Kenmore dryer
http://www.partselect.com/dryer+replace-thermal-fuse+repair.htm
Jun 14, 2008 | Kenmore 73952 Gas Dryer
Kenmore 63942 Dryer Logo
317 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
