Question about HP Scanjet 5470c Flatbed Scanner
I need a workaround with Vista or Windows 7 and an HP5470c scanner
  • HP Master
  • 10,322 Answers
Here you can download driver for HP Scanner.
Posted on May 07, 2010
I want to install the CanoScan Lide30/N1240U but there is no driver for Windows7. So it looks like I cannot use the scanner anymore. Is there anyone who knows a solution?
Go to site
http://software.canon-europe.com/products/0000466.asp
and select OS as Vista and language as English and press submit
and download windows vista drivers.
you can use Vista driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select Vista
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
May 23, 2011 | Canon CanoScan LiDE 30/N1240U
I HAVE A NEW LAPTOP WINDOWS 7 AND CANT RUN MY AGFA SNAPSCAN E20 IS THERE A WAY OF GETTING ROUND THIS
Hello r_maddox4
The only way is a workaround but there are some restrictions .
You need to have version Ultimate or Professional or Enterprise of Windows 7 .
If not , you need to have a Win XP install disc .
You can then come back to me for further assistance to work it out .
Otherwise , you need to purchase a new Windows 7 compatible device .
Best regards ,
fanaudi .
May 10, 2011 | Agfa SnapScan E20 Flatbed Scanner
I installed my scanner on windows vista business. It will not work . It worked on Windows XP service pack 3. Is there a driver I can download for Windows vista business? I need this scanner to work...
Unfortunately the last driver that Microtek released for this device was for Windows XP. I'm posting the link to Microtek's support page for this device below. You may be able to contact Microtek directly (contact info is on the support page) for a possible workaround.
http://support.microtek.com/product_dtl_2.phtml?prod_id=3
May 03, 2011 | Microtek ScanMaker X12USL Flatbed Scanner
Fix error 651 on windows 7
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip). This should help!
Jan 01, 2011 | Computers & Internet
I have windows vista X64 and can't find software for canon mf toolbox
I called Canon support; this is a known issue, and the workaround that worked on Windows 7 x64 was to use Windows Fax
& Scan (Start > All Programs > Windows Fax & Scan.
Mar 12, 2010 | Canon ImageClass MF5770 Laser Copier...
Scanjet 2200c under Windows 7
HP does not have a driver for this scanner with either Vista or Windows 7. One workaround is available in Windows 7 Pro or Ultimate. You can set up the XP mode and install the scanner within the virtual computer. Scanned files may need to be put on an external drive to transfer them between the two "computers".
I hope this helps.
Jan 10, 2010 | HP ScanJet 2200C Flatbed Scanner
Are there drivers for the agfa snapscan 1212u in windows 7 platform?
As far as I can tell, the driver has not been updated for either VIsta or Windows 7. If you have Windows 7 Professional or Ultimate, you have a workaround option. Install the XP mode and then install the scanner to that virtual PC.
I hope this helps.
Jan 05, 2010 | Agfa SnapScan 1212u Flatbed Scanner
HP PSC 1350 Windows Vista Support
I would check the HP forums as a more likely place to find an answer to this question...check here
May 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
Hp psc 1215 wont scan with vista
Introduction Some products do not have full scan functionality in Windows Vista. This is because full-featured Vista drivers are not available for all products, especially older products. However, the Windows Vista operating system installed on your computer includes a basic print driver. This driver allows you to scan an original and save it as an image using workaround methods. You cannot use the advanced scanning features that you might have used with your product before you installed Microsoft Windows Vista. Scanning an original and saving it as an image Follow these steps to scan an original document, and then save it as an image. Step one: Load the original Follow these instructions to load the original in the product.
  1. Raise the top cover of the product.
  2. Place your original print-side down on the glass.
    NOTE: The engraved diagram next to the scanner glass shows exactly where to place the document (usually on the right-front corner or the left-front corner).
  3. Close the scanner lid.
Step two: Workarounds for scanning an original and saving it to the computer Select one of the following three workaround methods to scan an original and save it as an image. Method one: Scan with Windows Photo Gallery
  1. Click the Windows (c01319360.gif ) icon.
  2. Click Programs .
  3. Click Windows Photo Gallery . The program opens in a new window.
  4. Click File , and then click Import from Camera or Scanner .
  5. Click Import .
  6. Click Scan .
Method two: Scan with Windows Fax and Scanning
NOTE: This feature and the following instructions work only with Vista Ultimate, Vista Business, and Vista Enterprise versions of Windows.
  2. Click Programs .
  3. Click Windows Fax and Scan . The program opens in a new window.
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scan using Paint
  2. Click Programs .
  3. Click Accessories .
  4. Click Paint . The program opens in a new window.
  5. On the Paint toolbar, click File , and then click From Scanner or Camera .
  6. Click Scan .
Nov 30, 2008 | HP PSC 1215 All-In-One InkJet Printer
HP Scanjet 5470c Flatbed Scanner Logo
274 people viewed this question
Seeker5211
Seeker5211
