Question about Formac Gallery 2010 20.1" LCD Monitor
My formac dvi monitor wont work as a 2nd monitor for my laptop
The monitor is connected via the built in dvi lead with a male dvi to vga converter which is connected to the vga port on my acer laptop. the laptop doesnt recognise that there is another monitor connected. any suggestions?
thanks in advance for any input.
  • 2,404 Answers
Try a monitor that has a vga output only, sometimes these laptops can't recognize the difference when there is a converter involved. It doesn't see the signal properly.
Try that and if a regular monitor works with vga then you know that monitor may not be compatible with that laptop because of the converter. You could also try another converter as well to see if that fixes the problem.
Posted on May 07, 2010
Struggling to connect my Goodmans Freeview+ HD recorder (HDMI output) to either the DVI (female) or VGA (female) input of my Samsung LE27T61B TV which is HD ready with a resolution of 1366 x 768.
They are different protocols. You have to have a converter than changes the protocol (protocol is like a language...it needs to be translated to a different language). They are available from eBay or amazon but they don't always work very well. Best thing to do is get a unit with the correct connections.
Jul 14, 2016 | Samsung Televison & Video
How do I connect a external monitor to my toshiba P55T-B5262 laptop
Ok I looked at the Specs on the laptop --- you have a HDMI port --- Same thing found on almost all tv's now days
-you need a HDMI to VGA or an HDMI to DVI converter --- very inexpensive purchase
Options #1
If the monitor you are trying to has this port:
-then you need a HDMI to VGA adapter
http://www.ebay.com/itm/like/350902230382?lpid=82
Options #2
-then you need a HDMI to DVI cable
http://www.ebay.com/itm/HDMI-to-DVI-D-24-1-Pin-Monitor-Display-Adapter-Cable-Male-Male-HD-HDTV-6-FT-/141210464113
Hope this Helps!
Sep 06, 2014 | Toshiba Satellite Computers & Internet
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
We were given a dell computer and that morning the people who gave it to us said it was working fine, they wiped it clean and we were goin to have to reinstall everything, but the monitor wont work plugged...
Does the light on the monitor show?
If not check poer cable - if so check the connection on the computer black cable with blue end.
Any beeping when the computer is turned on?
if so you may have a hardware malfunction with the tower.
Aug 29, 2011 | Dell Dimension 2400 PC Desktop
Hi there basically I have two ports on my monitor dvi and vga and dvi is connected with another appliance so that leaves me vga but when I connect my vga to my desktop the computer is on but there is no...
try with DVI port and see it works or not.
if worked buy a converting port (DVI to vga) and connect you video card Via DVI
and connect your other appliance Via VGA port by that converter.
Jan 09, 2011 | Computers & Internet
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
May 14, 2010 | Computers & Internet
Cannot get second monitor output to work on ATI Radeon X1200
A DVI-D signal is digital (whereas DVi-I is digital AND analogue) and can never be converted into a VGA signal without using expensive hardware boxes that convert the signal. These though tend to lose quite a bit of the signal quality. If I were you I'd look for a monitor with a digital connection, because I'm afraid this isn't going to work.
I'm sorry your problem can't be fixed...
Yannick.
@DickcanFixit: Catalyst 9.4 is the most recent.
May 30, 2009 | ATI RADEON Graphic Card
Connecting my laptop to my new TV
Hi there.
Check on the back of the TV for a VGA input port, if it has what you will need is a male to male VGA lead and a mini stereo to mini stereo audio lead to plug into the headphone port on the laptop to audio in on the TV.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Compaq Computers & Internet
Formac Gallery 2010 20.1" LCD Monitor Logo
174 people viewed this question
Top Formac Computers & Internet Experts
David Payne
David Payne
Are you a Formac Computer and Internet Expert? Answer questions, earn points and help others
