Question about HP mx705 17" CRT Monitor
Monitor fine with 1 PC, no RGB input after windows load on other?
My monitor seems fine when using it with the PC I'm currently using it with, which happens to be painfully slow (it's on windows vista basic & acer aspire machine), but when I plug it into the other PC (Windows XP, home built machine)it stays on until half way through it loading windows, goes black then says no RGB input. I'm guessing nothing is wrong with the monitor itself or the cable since it works fine on this PC, and it did work on the other one up to the other day. Please help!
  • HP Master
  • 2,404 Answers
Lower the resolution on the computer to 800 x 600 and then hook up that monitor see if it at least accepts that and doesn't go black. You may have to go into safe mode to do it plus then go back into regular mode.
Posted on May 07, 2010
Ive connected my vga to vga cable from my desktop pc to the rgb pc input on my lcd tv but it shows no picture. it shows windows loading but wont show my password entry or desktop page
Because your laptop needs it's display setting changing so your second monitor is active.
While on your desktop, right click once and a box will appear, choose "properties" at the bottom.
There you will see another box, choose the "settings" tab at the top right and this will show your display options.
Right click on the number two box and "attach" it.
You may also have to change the size of the display to fit your tv.
Hope this helps
Dec 01, 2013 | LG Televison & Video
How i use my samsung CRT TV as a computer monitor? my TV has A/V and RGB input connectors. and My PC has only VGA out put.
You'll need a VGA to Video composite / S-Video converter (commonly called PC to TV converter), this device will allow you to connect the VGA output to composite video input of your TV.
Feb 24, 2011 | Computers & Internet
Screen turns blue after Windows XP boot. It is
You cannot set your PC video resolution to 1920x1080 @60Hz?
Per user manual:
1. Set computer to a resolution supported by your HDTV (see Preset PC Resolutions). If your
computer supports it, we recommend 1920x1080 @60Hz.
2. Turn off the power to your HDTV and Computer.
3. Connect the VGA cable from your computer to the RGB PC jack on your HDTV.
4. Connect the 1/8-inch audio cable from your computer to the RGB PC Audio jack on your HDTV.
This step is optional and only needed to transmit audio from the computer through the TV.
5. Turn on the power to your HDTV and computer.
6. Select RGB using the INPUT button on the remote control or side of your HDTV.
Note: Refer to your PC computer user manual for more information about the video output requirements.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Sep 07, 2010 | Vizio VM230XVT 23 in. TV
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
How do you hook up the tv thru dvi out with a sony pcv-rs620g
There are several ways to do this. The two best are:
1. Get a DVI to HDMI cable. This will allow you to plug directly from your computers DVI to your TV's HDMI.
2. If your computer has an analog (rgb (vga) 15 pin) input, you can simply get a dvi to vga adapter and plug into that port.
Currently, I am using option 2 for my own use.
In the photo below, I point out the HDMI, RGB (VGA), and audio inputs. You must use the audio input but you have a choice of using the HDMI or RGB for video input from your PC. If you have the extra HDMI slots, I would use that. If not, the RGB is fine.
Mar 05, 2010 | Sony PCV-RS620G PC Desktop
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Mar 14, 2009 | ASUS Computers & Internet
Pc ready
There is a PC/DTV RGB input area with two audio jack inputs.  The input is a standard 15 pin PC jack. Hook it up to your PC video card input.  You can get the audio cable from Best Buy or a electronics store...split RCA on one end and the headphone jacks on the other to your PC. Then select the TV/Video source button on your remote until you see PC/DTV YPbPr screen appear.  It will search for the signal, find your PC and display the screen. You may have to go to MENUE on your remote to adjust the HDTV (1080i) frequency.... an option that only appears if there is something hooked up to the PC/DTV RGB signal input.
Nov 26, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
CTX
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
Apr 27, 2008 | Gateway FPD2275W LCD Monitor
HP mx705 17" CRT Monitor Logo
48 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
