Question about EIO Estate Bagged Canister Vacuum
Need a replacement handle for the hose on the EIO Varia Estate Vacuum.
3 Suggested Answers
advacak
  • 125 Answers
SOURCE: Eio Varia Estate Vacuum cleaner
contact the VDTA its a vacuum trade association. they will have contact info for all mfgs
Posted on Dec 02, 2008
SOURCE: were do I get replacement
4dfa5d4.jpg advacak
  • Rank: Wiz small_appliances_small.png
  • Rating: 83%, 100 Votes
contact the VDTA its a vacuum trade association. they will have contact info for all mfgs Call Suburban Vacuum Cleaner Parts at 1-877-592-5888 and they stock them.
Posted on Jan 07, 2011
Where do I get teh EIO Baria Estate or cottage replacement bags>
www.eio-vacuum.best-price.com
This is the web site that you can order bags from...if this helped you please remember to click on the yes box on the way out if you are satisfied with your answer. THANK YOU AND GOOD LUCK
Oct 10, 2010 | EIO Estate Bagged Canister Vacuum
Were do I get replacement bags for the EIO varia estate vacuum?
4dfa5d4.jpg advacak
Aug 24, 2010 | EIO Estate Bagged Canister Vacuum
I have an Aerus Guardian canister vacuum with a clogged hose. The tiny stuffed animal toy is lodged right below where the swivel handle meets the hose. Switching the air flow does not dislodge it. I would...
Consider this. If your vacuum is still under warranty, removing the hose will void the warranty on the hose. I strongly recommend calling an authorized dealer/consultant.
Although it may seem to be fairly simple to remove the handle, there are wires that need to be disconnected in order to separate the handle from the hose, gaining access to the toy. And reconnected. If not properly done, attempting this may lead to needing to purchase a new hose.
Apr 19, 2010 | Electrolux Guardian Bagged Canister Vacuum
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Replace an external hose to a D07 vacuum cleaner
remove the handle from the body of the unit slide the handle all the way out there is a small button on the plastic coller press it in and pull the handle free lay the hose on the floor and at the base of the hose there is a hook put one finger under the hook and just between the hose and the body you will see a clip that is locked into the body put your thumb on the clip pull it towards you and as you do this lift the hook and the hose coller will come out it can be hard to get it out so take your time
Oct 19, 2009 | Dyson DC14 All floors Bagless Upright...
Wand housing got pinched and now wand won't come out.
Hi there smartalec from NelsonVacuums.com.au here. I assume you mean that it got squashed and now the handle part that ordinarily slips inside the flexible hose is now permanently stuck in the flexible hose?.
If this is the case remove the two pieces as if they were one complete part. This can be done by removing the bin assembly, unclipping the hose / handle assembly at the top tilting it backwards and then unclip at teh bottom where the hose joins the body of your dyson vacuum cleaner.
Once you get both bits of the vacuum try and separate them again. It is unfortunately fair to assume that either one or both will need replacement but at least once their off the vacuum you will be able to see how bad it is.
By the way if you need replacement parts for your dyson vacuum cleaner send me a message or check out my website.
Hope this helps.
HAPPY VACUUMING ! :)
Aug 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Can the damaged hose 8 inces from handle be cut then replace hose
If the hose is non-wired then you can fix this yourself. When you Plug the cuff into your wall inlet does the vacuum turn on automatically? If so then you should be able to trim the hose with no ill effects other than losing eight inches of cleaning area.
If the hose has a switch on it's handle that turns the vacuum on and off, you will probably need a technician to fix the hose. Some wired hoses even have High Voltage lines in them and should never be taken apart.
Jan 11, 2009 | Electrolux Central Vacuum
Aug 12, 2008 | EIO Estate Bagged Canister Vacuum
Clog in handle/hose
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=579130
Clog in handle/hose
Posted by TCow on May 08, 2008
Small rubber ball got sucked up and is caught in the handle or hose. How can I take it part to remove the object?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. in some cases the Electrolux handle will come apart but id not then I use a couple of methods, if you have another canister vacuum or shop vac then turn on the Electrolux and the other canister vacuum and try to pull the ball out one way or the other. Or you can use a wire coat hander and create a little hook on the end and insert it into the handle portion of the vacuum to see if you can pull out the ball or loosen it so that it will roll out. One other choice that id you have a long small broom handle the length of the hose or longer and then you can push the ball out but the handle has to be smaller than the size of the inside of the hose and also be VERY CAREFUL… because it is an electric hose and it is very expensive so if you cannot remove the small ball bring it to a local vacuum cleaner dealer or the absolute last resort is to replace the hose, but most clogs can be removed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 08, 2008 | Electrolux Guardian Bagged Canister Vacuum
No Power coming thru hose handle
It probably wouldn't help, it sounds like the switch. Have you tried pushing the reset button? (It's a little red button on the end of the power nozzle.)
Feb 24, 2008 | Electrolux Lux 5500 Canister Vacuum
EIO Estate Bagged Canister Vacuum Logo
Top EIO Vacuums Experts
JoeVacs
Are you an EIO Vacuum Expert? Answer questions, earn points and help others
