Question about LG 22.4 Cu. Ft. Bottom-Mount Refrigerator - Smooth Black
The ice maker will not shut off on the LG refrigerator.
The icemaker on the LG refrigerator will not shut off and of course the ice container is beyond capacity of ice. When you pull out the ice drawer to grap some ice excess ice goes everywhere.
  • 316 Answers
The internal switch that is supposed to shut the ice maker production off when the bucket is full has failed. Replace your ice maker
Posted on May 07, 2010
Icemaker is making ice but will not dispense. continues to accumulate then over time ice in the bottom of the dispenser will freeze
I can think of two possible problems. The ice has frozen together and will not allow the ice screw to push the ice out the dispenser. Or the motor for the ice screw is broken.
1. Shut off icemaker with lever at icemaker
2. Remove ice container (either throw away ice or save in another container).
3. Put back empty ice container.
4. Leave ice maker off for about an hour.
5. After an hour , check if motor is working by trying to dispense ice. You should not expect any ice but you should hear the motor /auger moving.
A) If you do not hear any thing , you need to get your motor replaced.
B) If you hear the motor , mostlikely you had an ice dam which prevented the ice dispense from working..You can turn you icemaker on.
Oct 15, 2015 | Whirlpool Refrigerators
Ice maker does not shut off
unplug icemaker in and out
Jan 23, 2014 | Refrigerators
Lg side by side model number lrsc23915sw ,ice maker shut off arm only moves only about one half inch upword,front of arm attached to curved plastic piece this model was bought in canada
the icemaker arm on the L g are diferent dont try to pull up not a shut off arm this has a switch under side of ice maker if u kift up on the arm on this icemaker yo uwill need to buy a new icemaker and they arent cheap check for an ice jam between auger in icemaker if you havent pulled up on arm ive also seen the water fill tube to icemaker frozen
Jan 28, 2011 | LG LRSC26920TT Side by Side Refrigerator
Lg side by side model number lrsc23915sw how to turn off ice maker
I'm having trouble identifying that model number, but I can give you the generic answer. On most icemakers the "shut off" is lifting the wire arm to the up position. It should lock in that position. Lifting the arm shuts it off in the same manner that it stops the ice maker when too many cubes are in the tray. I have seen some icemakers that actually have a swich on the front side of them. But, they are in an obvious position so I'm guessing you don't have that style.
Hope this helps
Ice maker stopped making ice
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Icemaker won't stop making ice
there should be a saftey shut off bar or something in there to shut the ice maker down, look inside and see if there is a bar, or holes where a bar should be installed, if there is a bar, the the auto shut feature is not working you will need to replace it if thats the case, best of luck, hope that helped
Jan 18, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice maker
hi. thanks for the question. is the arm on the ice maker in the up position. it could be stuck in the ice cubes. the arm has to he up to stop the process thanks the appliance doc.
Oct 02, 2008 | LG LRFC25750 Refrigerator French Door
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
LG 22.4 Cu. Ft. Bottom-Mount Refrigerator - Smooth Black Logo
762 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
