Question about Ryobi Garden
How do i clean the spark arrestor on a ryobi ss30 trimmer?
    Scholar:
  • 47 Answers
Got a manual? They likely tell you there. If not:
Obtain and use the proper tools for removing the arrestor retention assembly/diverter and leaving the muffler in place right where it is at. Once the screen is in your hands? A blast of carb cleaner and a fine wire brush is all the attention it will need. Re-install, snug your retention screws/bolts and go play in the grass! :D
Posted on May 09, 2010
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
How do I remove the carburaetor locks on Ryobi ss30 seedeater I am a beginner lady learning to fix my own stuff
Remove carb mounting bolts. Carb obsolete not available. This may help: http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Dec 22, 2015 | Ryobi Garden
I have Ryobi head and I cAN'T get a spark Mod# RY30040A I need to know where spark ARRESTOR is.
Hi plattsacre
Your spark arrestor is inside of the muffler...you must dissassemble the muffler to clean or repair/replace it.
Please take time to rate me
Bud
Mar 18, 2013 | Ryobi Garden
Where is the spark arrestor on the RY26000
Hi James Ferguson
Your spark arrestor is in the muffler of the trimmer.
You will dissassemble the muffler and there will be a type of screen/metal with holes,etc...that is your spark arrestor.
Clean and reassemble and your good to go
Bud
Also go to the following webpage to see a spark arrestor cleaning, not your model but it will still apply to your weed trimmer maybe different steps.
http://www.youtube.com/watch?v=kA68zpEajnU
Oct 20, 2012 | Ryobi Garden
Where is the Spark Arrestor located on a Ryobi SS 30 Trimmer
It will be on the muffler. What you are looking for is a screen mesh. If you cannot see through this mesh then you need to clean it before putting it back into the muffler. You can clean it with a propane torch and burn off the carbon deposits.
Mar 30, 2011 | Ryobi Garden
How do i take a part ryobi cs30 trimmer to replace the pull cord?
Here's a link to step-by-step and a video for a Ryobi SS30 string trimmer. I do not believe there are many (if any) differences between those instructions and you trimmer.
Aug 18, 2010 | Ryobi Garden
I have a Ryobi brushcutter that is 4 years old.When I was using it the other day it just would not run at full throttle. I checked spark plug,air filter and fuel filter. No adjustments on carb. I have no...
Smokey 2 cycle oil will cause the exhaust ports to carbon up and plug the spark arrestor.
Remove the muffler, use a pick to clean out the exhaust port on the engine, and the muffler inside opening, then clean the spark arrestor screen, to assure yourself you are correcting the problem start the machine up with the muffler off, it should run like a charm, if it goes back to running badly when you reattach the muffler it may be clogged on the inside.
Jun 14, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Garden Logo
1,125 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
