Question about Acer AL1916W 19" LCD Monitor
I noticed the characters were a bit fuzzy or blurred and then the desktop size reduced so that there is a 1cm black margin around the top and sides on the screen. My cursor will not go into the black area. Any ideas on what I can do about this?
    Brigadier General:
  • 10,406 Answers
Use the LCD monitor's OSD (On Screen Display) to "stretch" the picture both "horizontally" and "vertically" to fill the viewable area.
Posted on May 07, 2010
Windows driver
.Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;} .Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;}
The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn aniso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Apr 03, 2010 | Radio Shack VGA PC Camera Webcam
Tip
How to Remove Scratches in Stainless Steel
Whether you can remove a scratch has much to do with how deep the scratch goes. Here are several ways to deal with this problem and restore your cookware, stainless steel appliances, countertops or sinks to their former glory.
Consider using a product made for stainless steel such as Scratch-B-Gone or Bar Keepers Friend.
Or, try spraying an all-purpose cleaner (such as Formula 409) on the scratches.
Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
Rinse the surface and wipe dry.
You may also use a solution such as WD-40 to help fill in the sctraches and coat the stainless steel on the unit(s).
on Oct 19, 2011 | Frigidaire Refrigerators
Tip
How To Properly Store Vegetables and Food
The first step in proper storage is making sure your refrigerator is at the proper temperature. You will want to make sure your fridge is somewhere between 34 degrees and 40 degrees Fahrenheit. If your fridge goes above 40 degrees, your food will spoil more quickly, but if the temperature is too low, the vegetables in your drawer will freeze.
Often, crisper drawers will have a mechanism to regulate how much moisture flows into and out of the drawer. Depending upon which vegetables you are storing, set the drawer to either let moisture out for drier veggies or keep moisture in for vegetables that need the humidity. Having a fridge with multiple crisper drawers is helpful in storing vegetables based upon their humidity needs.
Vegetables tend to be very sensitive to ethylene, a substance that comes from most fruits and a select number of vegetables. Because of this, storing fruits and vegetables separately is advised. Ethylene exposure is responsible for carrots turning bitter, the yellowing of certain green vegetables and lettuce turning brown. In addition to absorbing ethylene, some vegetables also absorb odors from other veggies. For example, the odor of apples is absorbed by carrots, cabbages and onions. If odor absorption occurs, it can affect the taste of the vegetable. Add a box of baking soda to the crisper drawer to help with odor absorption. After about two weeks, you'll want to shake out the top layer of the baking soda to maximize freshness.
Some vegetables benefit from being stored in a bag in the refrigerator rather than being out of a bag. These vegetables, such as artichokes, broccoli, cauliflower, cabbage and eggplant, should be placed in the crisper bin in perforated plastic or paper bags so that they can maintain moisture. However, some vegetables like lettuce don't do well with lots of moisture; for this reason, you should not wash your vegetables before storing, but before eating instead. With carrots, beets, radishes and parsnips, removing their tops prior to storage will help them keep longer. Similarly, the head of celery stalks should be covered before storing.
Unwanted 'dots' on printout
There is a dot somewhere on the drum, remove the drum and toner cartridge from the machine, then remove toner from drum. Look at the shiny roll, you can turn it from the black gear on the side. Once you find the dot use a cue tip dipped into little bit of alcohol and clean it off.
Mar 31, 2010 | Brother MFC 240C All-In-One InkJet Printer
I lost the CD for my VGA PC camera webcam can you help me?
.Normal {margin:0.0pt; margin-top:0.0pt; margin-bottom:0.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Times New Roman"; font-size:10.0pt; color:Black; font-weight:normal; } H1 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:18.0pt; color:Black; font-weight:bold; } H2 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:16.0pt; color:Black; font-weight:bold; } H3 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:14.0pt; color:Black; font-weight:bold; } The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn an iso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Mar 30, 2010 | Radio Shack VGA PC Camera Webcam
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
How can i install my gigaware 25-157 cam if i lose the disc
.Normal{margin:0.0pt;margin-top:0.0pt;margin-bottom:0.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Times New Roman";font-size:10.0pt;color:Black;font-weight:normal;}H1{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:18.0pt;color:Black;font-weight:bold;}H2{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:16.0pt;color:Black;font-weight:bold;}H3{margin:0.0pt;margin-top:12.0pt;margin-bottom:3.0pt;margin-left:0.0pt;margin-right:0.0pt;text-indent:0.0pt;font-family:"Arial";font-size:14.0pt;color:Black;font-weight:bold;} The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn aniso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Jul 31, 2009 | Toshiba Installation Software
Vga web cam gigaware
Apr 21, 2008 | Radio Shack VGA PC Camera Webcam
Gigaware webcam with mic
Its a plug and play webcam. I think it has got damaged or your operating system contain some virus. Check it out by connecting this web cam to another computer running xp.
Then let me know
cheers
Apr 03, 2008 | Radio Shack VGA PC Camera Webcam
Acer AL1916W 19" LCD Monitor Logo
169 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
