Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
After using the trimmer for a while it gets hot and then the head stops spinning. It only happens after being used for a while. Took it in but they did not run it long enough for it to happen. It is progressively getting worse.
  • 143 Answers
The plastic head is overheating and melting because it is not fit for the work it is doing. When it cools the plastic hardens and it works until it heats again. You need a new head. Stephen.
Posted on May 07, 2010
Why does the weed eater not trim even though it spins?
it is getting hot from friction because you cannot tighten it so the head spins but everytime it hits a wed it tries to stop spinniing because it is slipping from the bolt not tightened. fix the bolt hole with a tap and put in a new bolt
Jul 14, 2015 | Troy-Bilt Troy-Built Gas String Trimmer...
I have an echo gt 2000 weed eater. I was using it the other day and it was working great and all of a sudden the trimmer head would not spin. What could it be?
one of two things has happened. 1 the trimmer head has melted where it gets driven by the shaft and needs to be replaced or 2 you have a fault in the drive line
Jan 05, 2013 | Garden
Head not spinning shaft cable is.
place a screw driver in the slot the drive goes into and hold the trimmer head feel the head
Aug 16, 2012 | Troy-Bilt Troybilt Mtd String Trimmer...
Ryobi 975R head won't stop turning.
sounds like the idde is to high
Aug 06, 2012 | Garden
Why is the trimmer head smoking/melting?
I think the melting is in your the head the feed that hods the line. That's the plastic bit. I have had this happen not just with one brand either. The problem is vibration. if things are not properly balanced the head vibrates, the resulting friction causes heat, that causes more wear and more heat. End of strimmer head! I not buy them two at a time on ebay!
Jul 22, 2012 | Garden
How do I replace the old head with a new one?
Your old head should simply unscrew from the gear box. You should not have to disassemble the head to get it off. Some models have a small hole above the gear box where you can insert a small screwdriver to lock the drive shaft so that the entire unit stops spinning. Keep in mind that some models have left-hand threaded heads while others have right-hand threaded heads. In most cases, you'll unscrew the head opposite of whichever way the head normally turns while you're trimming. This is by design so that the machine doesn't unscrew the head itself while you're using it. You can find replacement heads for most makes and models of trimmers at PartsBuggy.com.
Aug 25, 2011 | Husqvarna 28cc Gas Line Trimmer
Line spins out from rapid loader and doesnt stay put. has happened with 3 units after using for a short period of time
I've been using these for years! It shouldn't happen after only a few uses! Make sure your line is at least 3/4 of an inch inside the trimmer head! If you have been doing that the teeth are clogged! Take it apart and use a triangular file to clean the teeth!
Jun 17, 2011 | Echo Rapid Loader, Trimmer Head
I need to replace the whole trimmer head and I dont know how to get the gear case off so I can put the new one on. Can anyone help?
To replace the trimmer head you don't need to replace the gear case. If you look closely about a 1/4 inch up from the safety guard you'll see a hole in the side of the "gearcase" assemby. (you may have to clean the old dead grass clippings off to see it) You can shove a rod into the hole that will stop the head from spinning freely and I believe you spin the head clock wise (reverse threads) to remove the head.
Aug 27, 2009 | Echo Rapid Loader, Trimmer Head
Black & Decker gh1000 trimmer head not spinning
The same thing happened to me. You either have a ruined belt pulley, or, hopefully, the belt burned out. Belts are easy to find online, but the housing is tricky to remove - see other posts.
I finally got it the plastic housing apart on my trimmer (there is one screw hidden under the label), only to find a total meltdown. The plastic pulley is ruined, and the only way to get it replaced is to buy a new motor (the most expensive part).
If your trimmer is no longer under warranty, then you can get a refurbished gh1000 for the price a new motor unit.
May 25, 2009 | Black & Decker Garden
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
303 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
