Question about Air Tools & Compressors
Require mehrer compressor model TRZ700 manual
How much oil do I need to add to air conditioning system? & how much freon is needed? truck has no owner's manual
I would do a cost analysis first. Do you have the necessary tools including a vacuum pump and manifold. How much will it cost to replace the compressor if I damage it? How expensive is a condenser coil if I put in too much refrigerant? What type of oil is in the compressor now? What refrigerant is being used? Do you have a leek detector?
If you cannot answer the above questions or afford the replacement parts I would suggest taking it to a pro. If you need oil and refrigrant then you have a leak that needs fixing first.
Dec 06, 2014 | Cars & Trucks
Craftsman service manuals
I am assuming your enquiry is about the type of lube oil used in the pump section of the compressor. It would have helped if you had provided the model number of the compressor. In any case craftsman suggests all oil lubed compressors use synthetic non-detergent compressor oil.
Something like this would be required.
http://www.sears.com/ingersoll-rand-ingersoll-rand-38440228-compressor-oil-synthetic/p-SPM2881704102?prdNo=1&blockNo=1&blockType=G1
Aug 13, 2014 | Air Tools & Compressors
Operating manual for campbell hausfeed paint sprayer # DH -3000
I found manuals/parts lists for your model sprayer at www.chpower.com, a Champbell-Hausfeld website. Under the 'service & support' tab, select 'manuals/parts lists' and do a search on your model.
Apr 17, 2014 | Campbell Hausfeld Air Tools & Compressors
Refrigerator Whirlpool model GD25BFCHB00 not working - no power to compressor. Note this is an electronic controled model. How can I determine what part is required?
May be timer problem. Rotate the timer manually (Back side of the refrigerator / bottom Near the compressor / inside the freezer) Refer diagram. Rotate then working... Problem Timer / Heater protector .. replace (inside of the freezer)
Mar 22, 2011 | Whirlpool Refrigerators
Lost manual for Craftsman professional 60 gal vertical air compressor model no. 919.727280 & require it to determine how much oil the compressor takes Thnaks
The manual for this can be found at managemyhome.com. Look under manuals. It requires Adobe to read it. If you do not have it there is a plug in there. Thanks BB
Sep 19, 2010 | Craftsman Air Tools & Compressors
2001 jeep grand cherokee looking to replace ac compressor
If you would like to view a manual that should help you out , go to autozone.com and there you can enter your yr/mk/model and view chiltons manuals online. But remember, most states require you to have your system evacuated by a licensed repair shop. What you can do, is pay a shop to evacuate the system, then pick up the vehicle and replace the ac compressor and then take it back to the shop and have them recharge it. That way you can save a little money by replacing the compressor yourself.
Jun 14, 2010 | 2001 Jeep Grand Cherokee
Why does the electric breaker trip when my compressor wants to draw current?
The breaker is tripping because the circuit is overloaded. In the winter this is a common problem with a cold compressor at startup. If it is doing it in the summer then it may be you have too small wiring or too small a breaker for the circuit. A 20 amp breaker can handle 12 gauge wire up to 20 amp load. If you need more then you must have 10 gauge wire on a 30 amp circuit. A 240 volt compressor requires a 30 amp breaker and 10 gauge wire. What make and model compressor do you own? On the compressor it lists the load and requirements. Tell me the make an model and I can tell you the wiring requirements.
Jan 09, 2010 | Air Tools & Compressors
How to reasseble the open compressor model esv 7*5 by own. we dont have repairing manuals.its an second hand purchased compressor
Not what you want to hear, I'm sure, but I'd recommend contacting your local Ingersoll-Rand distributor. These double acting, water cooled machines require substantial expertise.
A unit of this size (probably 20-25HP or so) is probably going to cost more to rebuild than a new screw compressor costs. However, they can be very efficient machines.
Oct 28, 2009 | Ingersoll Rand 2545/7100 Electric Air...
Laptop MSI bleibt Disktop schwartz
dai ammachen punda mathiriyada type seiurathu.
sunni naye.
Jun 05, 2008 | Computers & Internet
Air Tools & Compressors Logo
124 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
