Question about Bionaire BDQ24 Quietech Dehumidifier
My Bionaire dehumdifier suddenly does not work.
It gets run about 50 hours a year so it's lasted for the last 7 or so years. What could be the problem.
My dehumidifier keeps turning off after a few minutes. I have had it less then a year. It is a energy star 50 pint model. Can you help me.
send it to me. I'll send you an old brown whirlpool one that will last another 20 years for you. or go buy one at goodwill. 25352582-u40lsvyytnuesyuv3fbafhtd-5-0.jpg 25352582-u40lsvyytnuesyuv3fbafhtd-5-1.jpg
Jan 03, 2015 | Dehumidifiers
I HAVE A WHIRLPOOL 25 Pint Dehumidifier model AD25BBL2 serial starts with QM. Anyway it Seems to work ok as water does collect in water tray. About every 30 minutes it makes a single KNOCK NOISE. Unsu
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
May 21, 2014 | Whirlpool 25-Pint Dehumidifier
Our Haier dehumidifier, Model HD306 seems to be working okay except it is not gathering any water. Last year we had to empty the bucket every two days. The humidifier is in the same spot and under the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 18, 2011 | Haier Dehumidifiers
My kenmore 580.54501 dehumidifier runs and runs, but does not dehumidifer. It worked fine for 1.5 years. we looked through the troubleshooting list... alas nothing seems to work. could it be that...
ME TOO...I've bought TWO of these POS's in the last 4 years, and they both broke down in just less than TWO years...and Sears will do NOTHING for me!!!!
Nov 19, 2010 | Kenmore 54501 Dehumidifier
The dehumidifier runs all day but there is only a little water being produced. We have humidity set at 35%, and the actual readings are much higher. This is only a year or so old. The last machine worked...
coolant may be low - warranty should be 5 years
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 10, 2009 | Fedders A7DH45B2A Dehumidifier
I bought my unit last year and ran it, it worked great. This year it worked not so great and now it won't run at all?
try a hard start kit it has an electronic start instead of mechanical and has a large start capacitor to give an extra punch to get it going if it is stuck i put240 volts just to the compressor for just for a sec...
Aug 18, 2009 | Dehumidifiers
Dehumidifier running but no pulling any water from the room
Check float switch some of the unit have afloat switch hooked to the unit. Next check the condenser coilsThey do get stopped up cat,dog hair and just plain get dirty vaccuum them out and try unit. Rusty
Jun 12, 2009 | Bionaire BDQ24 Quietech Dehumidifier
Dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Jun 10, 2009 | Haier HDN655E Dehumidifier
Whirlpool dehumdifier not functioning
DUMPSTER would be the best plan
Sep 02, 2008 | Dehumidifiers
Bionaire BDQ24 Quietech Dehumidifier Logo
Top Bionaire Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Bionaire Dehumidifier Expert? Answer questions, earn points and help others
