Question about Vacuums
Hoover Light on
I have a hoover freespace pet bagless washable filters, i have cleaned out everything, and checked for blockages in the pipe but the red light for empty bag is consistantly on and suction is poor, please help hoover is only about 6 months old!!!!!
  • 25 Answers
ALTHOUGH MOST FILTERS SAY WASHABLE THEY DO STILL NEED TO BE REPLACE AS WASHING THEM SHRINKS THE FILTER AND EVENTUALLY CLOSES THE AIRWAYS. WHICH ALSO IF NOT REPLACE WILL OVER HEAT MOTOR IN MACHINE AND CAUSE MOTOR FAILURE.
Posted on Mar 27, 2008
SOURCE:
My Hetty Hoover has no suction, but when I take the filter out it has suction Please help!
Throw away your old filter if it is not cleanable. Only clean it if it is a washable filter. If not, buy a new one
Dec 10, 2014 | Hoover Vacuums
Vacuum not clogged but has low suction
Check all the pipes, there could be something stuck in them which hasn't come out.
Also check the base of the vacuum if there is something stuck in the base.
Lastly check if there are any leaks in the pipes.
Also check the suction without using the handle, by pulling the pipe in your hand and see if it has more suction.
Apr 28, 2014 | Hoover U6630-900 WindTunnel Bagless...
HOOVER Freespace TFG 5123 - Red Light?
Check the entire flow path from intake to bag. You may find it is clogged.
Dec 12, 2013 | Vacuums
Hi, I have the Hoover d14194 bagless pet vacuum..when I switched it on it worked but kept cutting out, I emptied it and cleaned the filters but now it won't even switch on.is there something I can
You could check the motor brushes, if they are worn and check for loose wire connections.
Another possibility is that there may be a break in the lead, plug it in and shake the lead, if it starts and stops you have probably found your problem with a broken lead.
Jan 01, 2013 | Vacuums
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Hoover wind tunnel 2 bagless vacuum not working
Place handle in low position and turn cleaner over so bottom side is up.
Remove the 4 screws in bottom plate and lift off.
Look on the left side of the agitator brush. You should see the belt there. Remove agitator brush roll and used belt.
Discard belt.
With lettering on outside of belt, slide new belt over motor pulley.
Insert agitator though belt and place belt in belt guide on agitator.
Grasp agitator firmly and fit it onto position by first sliding end opposite the belt into the rectangular slot on side of cleaner.Pull other side of agitator into place
Turn agitator making sure belt is not pinched between agitator and agitator shield.
If this does not take care of your problem, then check your filters for dirt and your entire vacuum for blockages. Both filters do come out. If you can't get a new filter right away you can gently clean the paper filter and remove a lot of dirt. (I recommend outside)! The other filter is washable.
Make sure it is well dried before replacing.
Good luck.
Aug 06, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover Freemotion Pets 200W has lost most of it's suction!
if you take out the dirt cup at the top there should be a half moon orange that releases. inside of this half moon is a washable filter. rinse with warm water and let it dry completly before putting back into the machine. this should restore your suction. hope this helps.
Jul 31, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Windtunnel quits picking up
clean or replace the main filter. this filter is non washable. the best way to clean is to use a paint brush or compressed air. hope this helps
Jul 25, 2009 | Hoover U8147-900 WindTunnel V2 Bagless...
Freespace pets cylinder hoover 2000w tfc6207
It is possible that the belt is broken.
Dec 31, 2007 | Vacuums
Vacuums Logo
339 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
