Precision temperature controller is tripping the breaker
When the controller is connected without the heating cartridges it does not trip, but if you insert the heating cartridges it trips. It looks like the controller is drawing too much power.
  • 109 Answers
Exactly what is tripping? and actually it sounds like the heat cartridge is drawing too much power, ( check amp rating on fuse and heater to see if they are in check )
Posted on Mar 30, 2008
SOURCE:
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
My tub keeps tripping the breaker, but after it kools down I can trip the breaker back on, but it hits 100 and trips the breaker again, could this be the heater?
What Trips?
  • the "Actual" electrical circuit breaker?
    • Is it GFCI Style?
or...
  • Is the high limit switch tripping?,
    • which isn't actually a breaker.
  • A circuit breaker is a breaker that toggles as a switch, and to reset it you have to switch the toggle switch ALL the way to Off position to reset, then switch it to on.
    • Same thing if it were a GFCI style, it just has a 'Test' button on the body of the breaker, that button is usually a white rectangular button.
  • Some systems have a GFCI breaker that looks totally differnent from above... It's located on the control system itself, very similar to what you may have in your bathroom or kitchen of your home! It will have a 'Test' button AND a 'Reset' button.
A High Limit Switch, acts like a breaker, as it will trip when it senses a temperature greater that it is set for as a safe temperature. Once that temp is breached, it will trip.
So... Which one is tripping for you? What are you resetting to turn it back on?
if circuit breaker, it has nothing to do with the 100 degree temp you mentioned. If that trips,= electrical problem, either a short or overheated electrical appliance (internal wires) aging motor pulling too much current, loose electrical connections generate heat, etc.
if High Limit, then possible overheat of water? Many times, failed thermostat. I already know what you're thinking... But I never saw water get Hot! But... Many times that IS just the case , it's just you never noticed the water hot, and it has been cooling down when you saw it.
Apr 14, 2015 | Pool & Spa
How to replace a fuse in a hotpoint
Check the circuit breaker for the plug the dryer uses. Open your house power panel and locate the breaker for the dryer. It will be 2 breakers connected together by a metal pin so when one trips it will trip the other. This shuts off 240 volts. Sometimes only one breaker will trip without tripping the other one. This leaves the dryer with 115 volts to work the rest of the machine but won't power the heating element. Replacing the breaker will fix the dryer.
Nov 17, 2014 | Hotpoint Dryers
Why doesn't my stove top and oven heat up
Check your circuit breakers in the power panel for a bad breaker. The breaker has a pin connecting both handles One breaker can trip without tripping the other. This condition will only allow 115 volts to operate the controls and light bulbs but will not power the heating elements.
Jul 14, 2014 | Frigidaire FEF336BC Electric Kitchen Range
I have a Lifestyles Phoenix Spa with a Wolfpac model 12404GH controller. The onboard circuit breaker trips when the temperature control potentiometer-knob is turned up past water temperature and when the...
IF when the spa control calls for heat and it trips the breaker when the heater comes on then you have a bad heating element and it will need to be changed.
Disconnect the power to the spa. Disconnect the two wires going to the heater and then turn the spa back on.
If the spa stays running without the heater attached then that will be your source of trouble. New heater and you will be all fixed up.
Jan 28, 2011 | Home
My heil heat pump has been tripping circuit breakers. It might run 8 hours to two days before it trips. I replaced the breaker. They put a hard start on the compressor. Now they say the next step is the...
Have you noticed what the outdoor temperature is when this unit is tripping the breaker? Does it seem to be at a higher outdoor temperature or at all outdoor temperatures day and night?
Did they check the run capacitor to see if it's good and the proper microfarads?
Did they check to see if the breaker trips when it's starting up or after it has been running awhile.
If it's tripping on start up then it's possible the next step is the compressor replacement.
If it's tripping after running awhile then it could be dirty indoor coil or filters,blower not running at full speed,low voltage, loose wire connection, points burnt on contactor and even a weak run capacitor.
Dec 30, 2009 | Heating & Cooling
Not working
If the circuit breaker tripped,then the unit is trying to work and the remote is certainly telling the unit operate, otherwise it could never trip the breaker if it did not receive a signal from the remote. Your problem may be with the outside unit that te compressor is stalled (having a hard time starting ) and this will cause the breaker to trip. You need a porfessional to diagnose if it is the starter control, or relay, or capacitor, or bad compressor, or bad terminals.
Nov 28, 2009 | Coffee Makers & Espresso Machines
The dishwasher starts and initially rinses the dishes without heated water. In the next part of the cycle, the water is supposed to heat to a certain temperature.Beginning this morning, in this second part...
Hi
The issue is with the heating element of your dishwasher, it is withdrawing very large amount of power and thus, the circuit gets overloaded and circuit breaker trips. You'll need to check for any short circuits around the heater element. And, also the resistance of the heater element, it should be around 1.4K ohms to 1.8K ohms.
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Dishwashers
Water heater trip circuit breaker
I would say you have a bad element in the bottom.If the water is cold and heat until the top thermostat reach it tempture,then switch the bottom element and then the breaker trip.So replace the bottom element.
Mar 09, 2009 | Rheem 81VP6S/430126 Water Heater
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
