Question about Canon PowerShot A75 Digital Camera
Flash not working
My canon powershot wont take pictures when the flash is on. Under the auto setting the flash is automatically turned on and it seems to just idle when i try to take a picture. It works fine when I manually turn the flash off.
  • 188 Answers
SOURCE: Canon PowerShot SD550
yes, the flash of your camera is not charging. needs repair.
Posted on Nov 06, 2006
poolseman
  • 206 Answers
SOURCE: Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
Posted on Sep 14, 2007
t00nz
  • 4738 Answers
SOURCE: Problems with the battery and the flash on my canon powershot A530
Know this is an old post but... Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mentioned that your batteries weren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on Dec 16, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Canon powershot SD600 - flash doesn't work
It could be the sensor or a short in the flash wiring. You should take it into a camera shop and have them look at it. You could be covered under warranty if the camera is less than a year old.
Posted on Jun 22, 2008
SOURCE: Cannon Powershot SD 870
you can change it to no flash by when your taking a picture press the right arrow
Posted on Jul 19, 2008
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
I have canon a640 camera. I am getting problem regarding taking pictures as the flash is not working. I have tried it on Auto mode, Portrate, landscape and others the result is same. Please help me in...
make sure the dial at the top of the camera is set to AUTO or the green camera icon. When you are in position to take a picture, press the left button on the circle pad on the back of the camera; it should look like a SQUIGGLY ARROW this is the sign for flash. that button should turn it on, off, at automatic based on the current lighting.
Hope this helps!
Mar 14, 2011 | Canon PowerShot A640 Digital Camera
My camera doesnt' work indoors. i try to take a picture and it doesnt' take when I'm in AUTO mode. However, when I'm in LANDSCAPE mode the pic will take. it seems like the flash isn't active in AUTO...
You must have a software glitch because the flash is supposed to be in the auto mode when the selector is in auto, unless you manually turn the flash off and the flash should go back to auto every time the camera is turned off and back on. Here's a work around. Turn the dial to indoor and use the flash button on the ring to set the flash to auto. In the indoor setting you can set the flash to on, off, or auto.
Dec 19, 2010 | Canon PowerShot A720 IS Digital Camera
Problem with flash on Canon Powershot SD870 Digital Elf
There is a problem with the flash or flash charge circuit. It will need to be repaired and may cost about $ 100 if not under warranty,
Apr 05, 2010 | Canon PowerShot SD870 IS Digital Camera
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Can't take pictures w/ flash
Maybe you have the ISO set to a very high number. Set it to "auto ISO".
Sep 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My flash quit working
You are correct in saying that the bulb needs to be replaced. Take the camera to any camera shop and they will replace it for you.
Apr 20, 2009 | Canon PowerShot SD1000 Digital Camera
No flash in "P" mode
In all of modes you can use "up" key to toggle between "always on", "auto"  and "off" mode for flash. (in some mode there is only auto and off.) also the flash light icon on top right of screen shows th status of flash. I hope this helps...
Aug 02, 2008 | Canon PowerShot A640 Digital Camera
Nov 03, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Powershot S1 Digital Camera: Flash won't fire
Make sure the camera is not in Document mode . Document takes a picture with added contrast so text stands out. Make sure the camera is not set to Infinity focus . When you select Infinity Focus, the camera automatically turns off the flash and auto focus so you get sharp, clear pictures. Make sure the camera is set to Fill, Auto, or Red Eye flash. See your camera manual for details about setting the flash.
Dec 31, 2005 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot A75 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
