Question about Vizio L32 32 in. LCD HDTV
Display WE are starting to see what looks like purple icicles coming down from the top of the screen
  • 178 Answers
I like that description, but what i believe you are trying to describe is a de-lamination issue, turn the set off if you see a shadow that looks like the "icicles" that you are talking about de-lamination, the lcd panel's diffrent layers comming apart. Unfortuinatley if this is the case the panel it's self needs replaced if it is out of warranty it will be cheaper to purchace a new set.
Posted on May 07, 2010
Testimonial: "Thank you you confirmed my fear."
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
Code purple when turning on computer
Code Purple is a problem exclusive to HP's, the easiest solution is to avoid them. However, it's already too late for you as it was for me. Basically it's an attempt to force you to pay them to service or upgrade your PC, or if you didn't learn the first time, buy another. Here is the most concise answer I found, tried to translate into plain english.
***PLAIN ENGLISH QUICK AND EASY FIX FOR ALL SYSTEMS****
***Windows 7 code purple or Windows Vista code purple***
With the code purple error on the screen, press shift+f10 (the shift key and the F10 key (at the top of the keyboard) at the same time) to open a little screen called a command prompt. (So, you get a little black screen with white text that says something about your Windows verison first and a little ways down you'll see "C:\>". It's all ready for you to start typing.)
Type the following line, just as you see it here...
notepad C:\hp\bin\checkdmi\checkdmi.cmd
so it will look like this C:\>notepad C:\hp\bin\checkdmi\checkdmi.cmd - Note the space between notepad and C:\
Press Enter.
You will see the text for the file listed in a window using a simple text editor.
Go to the beginning of the text. Press enter to make a space. Type this...
goto cleanup
So, whatever comes after, the first line looks like this...
goto cleanup
Save the file and exit notepad and restart your PC. You are good to go
NOTE: From my experience. If you received the Code Purple error during the restore process; after saving and exiting notepad, press and hold the power button until the PC shuts down, wait 15 seconds then restart. If you get a message during start up select "start windows normally". If you don't shut down using the power button and wait for the "windows was unable to finish........", you will likely get the same error again when the system boots. I don't know how to get back to the Code Purple error without doing the restore process again.
Feb 10, 2013 | HP Computers & Internet
Tv screen turned purple
Check the video output card for any loose soldering, or component damage. Absence of Green color is the problem. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 21, 2012 | Broksonic CTGV-5463TCT TV
Takes a while to start up and turn on. Sometimes purple pixels
you have a power supply problem, look for bad capacitors normally they are flat on the top, but when they go bad they get like a bubble on top. just replaced them. good luck
Jul 10, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Laptop screen purple psychedelic visual and then screen blank
Sorry to hear that you are having problems with the computer display.
Per your description, I believe the display controller was damaged by the power surge. The laptop may need replacement of the display OR use it with an external display.
Nov 06, 2009 | Computers & Internet
When i play Nancy Drew:White Wolf of Icicle Creekall the things she says are whited out on the bottom of the screen. How do i fix this.
You may be able to adjust this problem on the Start Menu, go to Options> Display Options> ( or something like this[I do not have this game]) and try to adjust it.
Otherwise there may be something wrong with your graphics.
Hope this helps.
Levi_xx
Jul 10, 2009 | Her Interactive Nancy Drew: The White Wolf...
Sony Wega 50" DLP bluish tint
the issue is the optical block. replace the optical block
Jan 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Purple tinted on preview window?
Canon fixed it without charge (outside the warranty). It's a well-known CCD malfunction that occurs mostly if the camera is used in hot or humid climate. Canon tech support was very helpful (by email) and even paid postage both ways.
Aug 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Purple Screen
Your CCD imager is broken...
Aug 31, 2007 | Fuji FinePix F470 Digital Camera
Vizio L32 32 in. LCD HDTV Logo
152 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
