Question about Watches
How do you adjust the time on a bentley Brietling watch
    President:
  • 2,501 Answers
You can get advice from one of their service centers which you can locate by going to their web site- http://www.breitling.com/en/index.php#/home/. On the lower left if a small menu, choose "service centers" and fill in the required details.
Posted on May 08, 2010
Breitling airwulf second hand not moving all other functions working ok how do I fix this
Send to brietling or a competent watch repairer who is able to get spares as brietling are a bit tight with spare parts
Jun 21, 2015 | Breitling Watches
Breitling has a weird noise when shaken (sounds mechanical) and seconds hand wont work (usually it does if you move watch)
Sounds pretty serious!
The most likely thing to go wrong is the balance wheel has become dislodged. The most likely cause of this is being dropped onto ahard surface.
It needs to go to a Brietling dealer for repair.
Feb 18, 2011 | Breitling Colt Oceane 504 Watch
How to set a breitling chronometre b-1
Thank you for contacting FixYa.<br /> THere are so many different Breitlings. They are there own breed of watch. I am sorry to say you will have to contact Brietling on this one. <br /> Here is a link you can try:<br /> <a href="http://www.breitling.com/en/index.php#/maintenance/north-america/">http://www.breitling.com/en/index.php#/maintenance/north-america/</a><br /> Best regards.
Aug 27, 2010 | Watches
Unable to reset brietling colt, even after ajusting stem to 1st and 2nd postions.
mcdevito75 here, Let"s hope your description of the problem with your watch is wrong. Try this sequence, First, wind your watch, the automatic continues to wind your watch when you where it but to get it started, wind it 20--30 times. 2nd, your crown locks down, turn the stem Clockwise to un-lock it (the stem) now pull the stem all the way out then back in 1/2 way to set date. Set DATE to DATE before the real date turn crown counterclockwise. Now pull out crown all the way and turn clockwise to set the DATE and time (real Date) push the crown back in and turn counterclockwise to lock the crown. If this doesn"t work, look for a small watch repair shop in your area for this adjustment.
Jun 28, 2010 | Breitling Aeromarine Colt Ocean A64350...
My watch ticks for 10 to 15 seconds then then stops then i shake it and it continues then stops again what could it be
You have an self winding watch and to wind is up fully using the self winding mechanism you need to shake it for some time.
I think it is likely that you can winding it manually using the crown. You may have to pull the crown out to find the manual winding position.
The crown may be locked in and if it doesn't pull out , try turning it anticlockwise then pull it out.
You should have some instructions with your watch, if you haven't contact your supplier and ask for a copy.
If you wish to find your nearest retailer, go to "Brietling.com" for a store locator.
Feb 19, 2010 | Breitling NEW BREITLING BENTLEY 6.75 MENS...
I want to remove the front glass of my watch
You can do it only after the movement is taken out. And for glass removal you need a special press. Save your nerves and your watch - visit your nearest watch maker and ask him to do that.
Jan 29, 2010 | Casio Watches
Hello ive got breitling 1884 bently it has numbers on back j44382 01/05 been to jewellery shops and they are not sure is there some were else i can go to check it out
This looks like one for the archives of Brietling!
If you go to "www.breitling.com/en/index.php"/contact/", you will see a "contact" address and also a menu for finding your nearest dealer.
A dealer might be able to investigate your watch for you, although I suspect that it might take some time.
Jan 26, 2010 | Breitling Hercules 246/GRY/PROF
Is this a real or fake serial number E56121.1 for a brietling watch wondering if its a copy or real
Not true, it is real, I've got the same breitling and I know it's real. It's an emergency watch generally used by military personnel.
Sep 01, 2009 | Breitling Watches
B-1 brietling
Well if the watch is performing its functions properly then there's nothing wrong with it technically. The only way one could make it require less turns would be to custom make the necessary parts with different ratios and unless you have got lots of money to spend on that .......
Jul 27, 2009 | Breitling Aerospace 455 Wrist Watch
Breitling problem
This usually occur when the hairspring is disturbed ( some grease, dust particle, etc). Can be magnetized as well.
You need to find your nearest watch repairer and ask to overhaul your watch. After that it will run like new.
Jan 03, 2009 | Watches
Watches Logo
46 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
