Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Upper arm not spinning
The upper arm is getting water to it but it is not spinning due to not having enough pressure. What could be the cause?
    President:
  • 949 Answers
Typically this is a sign of debris in the sump area. I have put together instructions on how to clean it out if you are up for it. Follow the link and let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on May 07, 2010
Upper arm does not spin
If the sprayer arms continues to get caught, see if your racks can be adjusted in height. Some can be moved up or down by the side brackets. Otherwise freely spin it with the unit off and see if it is just getting caught on a pot/pan in the unit. Otherwise, it may not be getting enough water pressure to turn it completely around.
Aug 22, 2012 | Electrolux EWDW6505GS Fully Integrated...
My dinner plate stops the arm rotating, why? model fdud4812
Both upper and lower washing arms operate on the water pressure and angle of water flowing thru them.
Pressure provided by water pump.
Just about anything that contacts the rotating arm can stop it.
Best thing to do is re-arrange items in dishwasher so that arms can spin freely.
One can always spin washing arms by hand to ensure proper clearance.
Hope this helps...
Jul 30, 2011 | Hotpoint Dishwashers
Upper and lower spray arms are not spinning
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
May 06, 2011 | Microwave Ovens
Top wash arm doesn't spin.
This is usually due to restrictions from debris in the sump area of the pump, it will not allow enough pressure from the pump to spin the upper arms. I have put together some instructions on cleaning this on your model, follow the link below and let me know if it was helpful.
Whirlpool pump cleaning
May 28, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
No water pressure in dishwasher
bosch shu5312uc upper spray does not spin. pours water through the center section thus not propelling the arm. any ideas? should the upper arm have any o-rings
Dec 06, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Suspect blockage top rotating washer arm does not spin
Both arms (upper and lower) are fed from the back of the machine, when you close the door the arms make a water tight seal with the pumped water in your washer.
Check to see that when the machine is full that both the arms will turn with very little pressure. (watch out for forks sticking out of the cuttlery tray etc.)
You can usually clear a blockage by putting a bag over the back of the arm that engages with the pumped water on the arm that "IS WORKING" this will increase the pressure to the arm that is not working usually freeing the obstruction.
Nov 07, 2009 | Kenmore Dishwashers
Lower and upper spray arm will not turn
If the spray arm is not binding due to worn out plastic bushings, then it could be a lack of water pressure, because it is water pressure which makes the arm turn.
Give it a gentle tap in a clockwise direction,,does it spin easily?
If it does,,then it will be lack of water pressure that will be the cause.
Possible pump wear or failure.
Jan 30, 2009 | Maytag MDBE790 Built-in Dishwasher
Upper arm not working
I had similar problem. the problem was due to having not enough water pressure in the line to the upper srapy arm. Did the following:
1. removed debris from sump assembly;
2. removed wash motor and clean clogged separation screen; and
3. sealed with Teflon tape manifold and probe manifold of the upper sray arm.
If you google for 'whirlpool 8178022' you should be able to get KD-12 repair manual.
Goof luck.
Amjad
Dec 09, 2008 | Dishwashers
No water to upper arm.
check to see if you are getting enough water.should be about 1/2 under the heater.if you are getting enough then check the chopper this is under the lower spray arm.could be broken.
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
74 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
