Question about Toshiba 56HM66 56" Projection HDTV
Can a y67lmp be used instead of a y66lmp in a Toshiba TV
  • ryanmkrogh May 07, 2010
    My roommate has gone through 3 lamps in the last year. I figured he was doing something wrong so I pulled the bulb out to see if it was the right one and it said y67 not y66 which is what the tv indicates on the back.
  • 8,197 Answers
Yes you can use the y67lmp instead of the y66lmp.
Posted on May 07, 2010
Toshiba tv mw24f52 usb not recognized
Try using different USB. If you have too many files on the USB at the root itself, instead of under sub-folder, you might encounter this problem as the TV may not have enough memory to load it. Just refer to your operation manual for formats supported.
Jul 18, 2012 | Toshiba Televison & Video
Had my toshiba regza 42rv530u since March 2009 a few days ago it cut off and will not come back on, the yellow light flashes at the bottom of the tv, 3 blinks pause 3 blinks etc....
try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
May 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
My Toshiba 55HT1U is showing 480p instead of 1080p. Why is it not on 1080p?
It is probably your video source. If you are using component video, some devices only output 480p.
Check the settings of your sources. The TV will display only what the device sends to it.
In most devices under a settings directory there will be settings labeled "Video" or "Resolution" Changing these settings to more appropriate High Definition resolutions should solve your problem.
Mar 17, 2011 | Toshiba 55HT1U LCD TV
It seems the IR has gone out on our Toshiba 27AF44. We are told we need to provide a part number in order to have it fixed, but cannot find that number. Help??
Hello
The infrared sensor of your Toshiba Tv seems to be of normal type to which most of the colur tVs uses. You can check it with fitting an other number instead of the present one, and will work I thinks. It is a three terminal sensor, a standard remote sensor is used. Toshiba may printed some code of their own to it, that is all. OK.
Jan 11, 2011 | Toshiba 27AF44 27" TV
The tv i have is an 52 inch big screen. The model number is 50hmx96, the serial number is 30405011,and finally the lamp number is y66lmp and that is where my problem comes in, i was watchting the tv and...
Looking at the back of the TV the lamp door is on the bottom left. Loosen the one screw holding it on. Remove the lamp door. Inside is the lamp unit. Loosen the two screws on the left of the lamp unit. Grab the handle on the lamp unit and pull it straight out. You may want to vacuum the dust (and glass) off at this point. Slide the new lamp unit straight into TV until it's fully seated. Tighten the two screws on the lamp unit. Re-install the door and tighten the screw. Lightweight gloves are recommended for this procedure.
Apr 17, 2010 | Televison & Video
I need a remote control code for a toshiba tv. model number NR 27 WL 46 B. I want to be able to use my freeview plus box remote control on my tv
toshiba web statement says they wont issue the codes for remotes as they want to sell you a new one. Thats fine, mine wasn't broken, i simply wanted to use my freeview remote instead. i found the answer by going to top up tv's web site.
Dec 27, 2009 | RCA RCR450 Remote Control
40 inches toshiba (40RV525U) no CC with dvd movies
That I don't think you can do - the CC is fed by the digital tuner, while the subtitles are fed by the DVD player.
Oct 17, 2009 | Toshiba 40RV525U 40 in. LCD TV
A toshiba SD-37VSR DVD player that the TV will not recognize
if you are using the hdmi or DVI ports you need to make sure that both the player and tv are HDCP compliant (it will say on the box usually) otherwise, try using a different output from the player going into the tv. (try the composit or component instead of the digital outputs)
May 26, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Apr 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
Need codes to access TV menus
The solution relies with the remote. press the menu button and use the +/- buttons beside it instead of the volume or channel buttons. This TV was at a work camp in northern Alberta and the instructions were not available. Hope this helps others who do not have instructions available.
Apr 18, 2009 | Toshiba 13A25 13" TV
Toshiba 56HM66 56" Projection HDTV Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
