Question about HP Pavilion ze2000 Notebook
Hi my laptop was dropped, it was charging at the time. I think the part inside the laptop was damaged. The charger cord doesn't connect right, so I have to bend cord to get to start charging. I have had to replace charger cord two times now. ;(
    Brigadier General:
  • 10,406 Answers
Take the computer to a qualified technician, and get it repaired -- much cheaper than replacing the charger a few more times.
Posted on May 07, 2010
How do i fix a battery on a samsung tablet
The problem may be a frayed wire inside the charger cable right at the connector, or the charger jack may be worn or have a cracked solder connection. If it charges reliably with a different cable (such as a USB cable connected to the computer, it is probably the charger cable. If it has to be wiggled to get it to charge with a known good cable, then the charger jack should be replaced. This requires an expert technician; the solder connections are very small, and the circuitry requires special handling because it is easily damaged by static electricity.
Apr 28, 2016 | Samsung Galaxy Tab 2 7.0
My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Dec 11, 2012 | Computers & Internet
Will a laptop battery become damaged if you use the computer while it is plugged in? I do a lot of photo editing, and leave the computer plugged in for long periods of time, so that it doesn't di
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Laptop batteries vary from laptop to laptop. i suggest you Google the Internet for a battery for your model laptop.
Oct 25, 2012 | Acer Ac Adapter Charger For Extensa...
I was on the phone with my BB Torch, then the battery ran out, i got back the next morning, tried to put it on charge, nothing happen, no red light, no indicator , nothing, tried the charge for few ghours...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. If the red light doesn't come on, connect the charger and put the battery inside. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 09, 2011 | RIM BlackBerry Torch Cell Phone
I have a problem with my DC In port. I have to finagle my cord in different directions to achieve a charging state. Do you think I need a new charger or is there an easy way to fix it
If the DC input port feels loose then thats the problem. If not then the cable might be damaged on the inside. Happens if the cable is rolled up and unrolled frequently :)
BD
Sep 06, 2010 | Sony VAIO VGN-FE670G Notebook
My Dell Laptop syas that my battery is charged. But when I remove the ac power cord the computer immediately shuts down.
I repair laptops professionally and work on many Dells. Here are the possibilities.
1. The plugin connection where the battery meets the charging contacts in its bay where it seats are malfucntioning and the software is reading it incorrectly. To see if this is so, push the small round black button on the battery next to the 5 little dots at one end. If none of those dots light up green, the battery has no charge and the connection I spoke of above is damaged or malfunctioning beyond where you can see. If all the dots light up green, the battery is likely fine but the laptop can;t connect to its charge at the plugin.
2. The basic software (BIOS) is reading the charger/adapter incorrectly and although saying it is charging or charged, the actual charger is ruined inside in the compartment for charging the battery. Dell chargers can actually be incapable of charging the battery but still run the computer on direct current while plugged in.
3. The battery is no longer able to be charged, but is giving a false reading.
4. The DC Power Jack (into which you plug the charger) is only partially damaged and while able to power the laptop directky, cannot charge the battery. (Check to see if it is loose and woobly when you plug in the charger.
The easiest and least expensive way to troubleshoot and fix this yourself is to start with the charger. They can be had on eBay for about $20. Keep in mind that if no green lights show up on the battery, it might be your first choice and it's about the same price.
I hope I've given you enough info the help you determine your true problem.
Regards,
The Selkie
Aug 29, 2010 | Dell Inspiron 6000 Notebook
It's on but not charge
If the light on the adapter was flashing, I would certainly replace it first. You can buy recertified chargers from each computer manufacturer and save $$.
I would also check where the cord from the charger plugs into the laptop just to make sure nothing had gotten inside the jack plugin area and may be preventing it from seating correctly.
Dec 07, 2009 | Televison & Video
Can't charge battery
Remove the battery and try if the PC turn on connecting to direct currrent.
If it turn on (whitout battery), the issue should be a connector problem or a damaged internal recargher.
Oct 19, 2009 | Toshiba Satellite A75-S2112: A75-S2112...
HP Pavilion ze2000 Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
