Status message - E02-02 - what does this error mean for a Panasonic DP-C213? It seems to be preventing some of my users from printing. Thanks.
E2-02 means there is an error with the lifting motor assembly for tray
#2. You will not be able to use your tray #2 until it's fixed. You can check
it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will
need a service technician to fix and replace it.
Testimonial: "Thank you. You'd think you'd be able to search for this answer on Panasonic's Industrial site, but I couldn't even find the model number let alone the error code. Thanks for your help. "
