Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Problems with WD Mybook when connecting via FireWire400
Hello
The problem is quite similar to this one:
http://www.fixya.com/support/t368929-mybook_500gb_home_ed_hangs_winxp_sp2
The difference is: MY PC starts but it takes very ver long while starting with the drive conncected via FireWire! Normaly the "Windows Starting BAr" runs about 5-7 times until XP is loaded.
When the Drive is connected is takes about 25-27 times !!!!
Exactly the same issue on my Laptop!
I already installed a bios update and the microsoft FW-Patches --> no change!
When the Drive is connected via USB or plugged in after XP has started it works absolutely fine!
However I want to use FW and dont want to remove the plug everytime a start the PC.
Hope there is a sollution!
cheers
I'm afraid this does not help!
Any updates?
Posted on Jul 03, 2008
Check out this possible solution:
http://support.microsoft.com/kb/885222/
Posted on Apr 29, 2008
  • Anonymous Mar 19, 2009
    Have you checked for a Firewire driver update for your system?
    Check the manufacturer's site for your system board or expansion board, which ever has the Firewire port.
My 320GB WD Hardrive keeps blinking. It is connected via usb 2.0 into my laptop (windows7). Computer Management says it's working properly and it displays all the folders but when I want to open the...
It seems that your Harddrive has problems with internal Micro USB connector. WD, Transcend and Seagate brands are having such kind of problems.
Try to adjust the micro usb cable in such a way that your data transfer or ongoing activity will not hamper. Else to have perfect solution on your problem, backup complete data from the HDD and hand-over the HDD to the nearest WD technical department.
They may diagnose the issue and if not resolvable, will handover new WD Harddrive.
Thanks,
Amar
Oct 07, 2010 | Western Digital 320GB MyBook External USB...
Connected but not detected?
Hi, You need to run updates for your computer. Go to start, program, windows update, run and install all the updates, look especially for any update for hardware, select it and let it install. Leave the My book attached to the computer while searching for updates. Good luck.
Dec 21, 2009 | Western Digital My Book Essential Edition...
Problem
There is surely a reset button...Find it out...READ THE MANUAL
Jun 22, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
Connection problems with my Western Digital MyBook EE 2.0 320 GB.
Go to Programs and Devices and see if your Western Digital MyBook is even listed on your computer.
Jun 28, 2017 | Western Digital My Book Essential Edition...
WD My Book 320 Drvive not recognized via firewire conncetion
if there is softwear uninstull it and renstull if not then check to be sure the board is pluged in
Nov 30, 2008 | Western Digital My Book Essential Edition...
WD Hard Drive Not Detecting
Yes, this can be done via the user web interface, by typing in mybookworld or wdstorage into the web browser and the shared storage manager should come up. If you go to general setup there should be an option to update network settings.
Oct 31, 2008 | Western Digital 500GB My Book World...
Trying to connect a Mybook 1Tb network drive to N1 Vision
Hi! I have an N1 Vision with similar problems. I have done some research and found that we are not alone with this issue! Two solutions are possible: 1) If yours is version 1 (1000) of the machine, Belkin recommends that it be swapped out for version 2, which apparently has firmware/hardware changes that fix this (unverified; it would seem to me that this would require a whole new DHCP approach) and 2) I've found that if you go through the process of unplugging the device for 2 minutes, replugging it and then refreshing the DHCP table, after between 1 and 5 iterations, the device should appear. I'd also advise you to shut down (for troubleshooting) the software firewall in the router (you'll still have the NAT firewall), that might eliminate a problem/conflict somewhere in your network!
Good luck and let me know if this helps!
Bob
Sep 23, 2008 | Belkin N1 Vision Router
WD MyBook 320 GB Premium - Retrieving Data
You should buy a program called "Partition Table Doctor". I went through the EXACT same thing and it was just a bad partition on my mybook which is the EXACT same as yours is. It cleared up the problem for me. I still have problems with my mybook so i wish that I bought a different hard drive, but oh well.
but try "Partition Table Doctor", it will scan your mybook and fix any partition errors with it.
I was in the same boat as you over a year ago and trust me, "Partition Table Doctor" is a LIFESAVER!
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
157 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
