Question about Husqvarna 28cc Gas Line Trimmer
323 L Trigger
How do you put back together the trigger mechanism for a 323L weedeater ?
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Weedeater xt200 broken throttle lever
manddmower.com
part # will be 530038682
Posted on May 31, 2009
e-Guru
  • 3917 Answers
SOURCE: MY WEEDEATER STARTS FINE ,
Hi
Remove and disassemble your carburetor and clean it thoroughly. Reassemble and adjust.
Also check this link if it helps:-
http://www.ehow.com/how_7852165_poulan-dies-throttle-trigger-released.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 19, 2011
plink_plonk
  • 1807 Answers
SOURCE: I/m replacing a broken part of the throttle trigger mechanism of a 325C Husqvarna trimmer. there is a apring that returns the trigger to its original position. Where does the spring attach?
Hope this helps you a little, Il looks like it should sit between the throttle and the trigger interlock on the top of the handle.
Posted on Apr 12, 2013
I have a fs 55 stihl weedeater I had it on my fourwheeler and hit a tree with the shaft it broke the trigger release button and caused the trigger to pop out i could still use it until I attempted to put...
in the trigger handle there is a cable that attaches to the throttle. This cable has a ball end (just like a bicycle brake cable). You have probably popped it out when you refitted the lever. split the handle and refit to trigger
Sep 12, 2013 | Garden
How to put a rotozip rz10 back together
Hardest part is getting the trigger mechanism back in the right position while putting the screws in place. Everything has a slot/groove it fits into before both outside covers can be put together. One side will be easier to hold the pieces while the other simply covers them. A spot of glue (elmers) may help to hold trigger in place and the wires.
Apr 22, 2013 | Bosch RotoZip Spiral Saw RZ10 - 2100
Can't put together my husqvarna 323L weed trimmer's spark plug wire
Push the wire all the way through the HT cap.you may need to use pliers to pull it through, Then use the pliers to pinch the wire spike into the cable, use a little oil on the cable to help it slide back through.
Aug 31, 2012 | Husqvarna 323L
Trouble reassembling a daisy buckmaster 840 bb gun. We can not figure out the trigger mechanism in order to fit the side panels back into place.
1) Stack the trigger, seer (long black metal piece) and trigger block (large L shaped silver piece) on top of each other, with the seer in the middle.
2) You should have 3 springs, the long one attached to the end of the seer, the skinny one on the bottom of the seer and the fat one back between the trigger and trigger block on the back side
3) Compress the trigger block and the trigger together thus compressing that spring between them, keeping everything together. Now back the entire unit into the stock cavity. This is tricky and will take some practice. Be sure to keep the pieces squeezed together.
4) Insert the pin through the side which is countersunk. It only goes one way.
Jul 19, 2009 | Toys
Trigger jamming
I suspect that the cable to the carb is binding. Make sure when you reassemble the box, the cable works properly. Put the box together loosely and keep checking the action. Position the parts if it binds. Good luck!
Mar 20, 2009 | Echo Garden
Repairing
http://www.crosman.com/airguns/service/manuals/crosman-rifles
There are two manuals for the 766 on this page.
My problem is figuring out how to take it apart.
Nov 25, 2007 | Crosman (4032)
Husqvarna 28cc Gas Line Trimmer Logo
170 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
