Question about Dymo LabelWriter EL60 Thermal Printer
Dymo labelwriter el60 is not printing clearly
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
SOURCE: DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
YES YES YES
i plug the damn thing and it will work
Posted on May 23, 2008
SOURCE: New labelwriter 400 turbo will not print under windows 2000
I had the same problem and accidently discover it was something very simple...at least in my case. I noticed the power cord connection was very good.. I notice the light on the transformer (cord) was sometimes green then it would go out. When I unplugged and then put some force into reconnecting the printer worked. Hope that helps.
Posted on Oct 06, 2008
Unplug the printer and wait 30 seconds then plug it back in. Mine printed everything that was in the queque.
Posted on Oct 16, 2008
  • 4 Answers
SOURCE: dymo 400 labelwriter does not print unless shut down and rebooted
It could be how you have loaded the labels. If you have loaded the labels and there is a small gap between the spindle and the roll, it will print one label and give a error-printer message and stop working until you unplug it for 30 seconds and plug it back in. I would reload the labels from scratch and ensure there is no gap.
Posted on Aug 06, 2009
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
Need printer driver for windows 7
Hi, David. I had the same problem, and there is a solution. There isn't a driver for Windows 7, but under Windows 7 you can install a virtual machine, that runs a fully licensed copy of XP on your machine. You can download this from Microsoft. Once you have installed a virtual XP machine (and it's not hard at all to do - maybe 10 minutes), you can load the DYMO software and drivers for XP, and your LabelWriter EL60 will work just fine.
Regards,
- Jim
Dec 16, 2009 | Dymo LabelWriter EL60 Thermal Printer
My Dymo LabelWriter 400 Turbo stops printing after it has printe
Did you change the number of copies to print prior to printing?
Jan 16, 2018 | Dymo LabelWriter 400 Turbo Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Error: Will not print
Hello Sir,
To check the printer settings in Windows 95/98/2000
1. On the Windows task bar click the Start button, point to Settings, then click Printers.
The Printers window is displayed.
2. Right-click the EL40 or EL60 or EL Turbo icon and select Properties in the shortcut menu.
The Properties dialogue box is displayed.
3. Click the Details tab, then click the Port Settings button.
The Port Settings dialogue box is displayed.
4. Verify the following settings:
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo, 330 Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo, 330 Turbo)
5. Click OK to close the Port Settings and Properties dialogue boxes.
6. Click the Close button in the upper-right corner.
The Printers window is closed.
To check the printer settings in Windows NT
3. Click the Ports tab, then click the Configure Port button.
Select the COM port and click the Settings button.
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo)
7. Click OK .
Thanks
Good Luck
Don't forget to comment
Cheers!!!!
Feb 20, 2008 | Dymo LabelWriter 320 Thermal Printer
Dymo LabelWriter EL60 Thermal Printer Logo
48 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
GuruGrundy
GuruGrundy
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
