Question about Canon imageRUNNER 5570 Copier
Where is waste toner receptacle? - Canon imageRUNNER 5570 Copier
  • Canon Expert
  • 287 Answers
Hi Gail. On the right side,rear lower corner, you will find a cover that's about,oh 5 inches wide and about 15 inches tall.It is secured by 2 screws at the top and has 2 small "legs" at the bottom that fit into the frame of the copier to keep the bootom in place.Remove the top 2 screws and allow the cover to "tilt"away from from the copier top first.Look down and you will see the "legs" and the notches they go in for re-installation.Once the cover is removed the waste toner bottle is exposed.Slide it out and pour it into a trashbag,being careful not to spill it or cause an inordinate amount of airborne waste toner.Reinstall.NOW,for this model Canon you actually have to tell the device you have emptied the bottle.You will need to go into service mode.You do this by pressing the ADDITIONAL FUNCTIONS button,then release it,then press the numbers 2&8 at the same time, release, then ADDITIONAL FUNCTIONS again.That a 3 step process that will bring up the service mode screen. Press COPIER.You will see several tabs across the screen at the very top..The tab at the far right says COUNTERS.Press it.New screen shows up.Press MISC in the lower left corner.You will see FIX-WEB and WST-TNR.Select WST-TNR.To the right of this field you will see a value that's probably around 300,000.Now go to your 9 key pad and at the bottom you will see a "C" which means clear.Press the "C" and the value next to the WST-TNR box should clear.CONGRATULATIONS!!!! Have a good day. :-)
Posted on May 08, 2010
Testimonial: "Great - lots of detail on how to do this."
3 Suggested Answers
SOURCE: having trouble replacing waste toner receptacle on Canon imageRunner 3750
Hi you need to take right cover of the machine off the toner bottle is there get out dump and clean the bottle on the top inside and put back on and machine will reset auto.....
Posted on Jan 08, 2008
iservice
  • 318 Answers
SOURCE: canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Posted on Jun 09, 2009
IR 5065. Where is waste toner receptacle located?
You must empty the toner box and with soft clothes try to clean all the sensor window on used toner box and put it again.
Mar 03, 2016 | Canon Image Runner Toner Black...
How can l solve Error Code l4 02 in Sharp AR-M451N Copier
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Nov 25, 2013 | Sharp AR-M450N Copier
Xerox 7120 waste toner error ...
The trick about cleaning out the waste toner container is you have to also swab out the clear plastic piece the optical sensor reads so the device knows the waste toner is full. Clean that out and you should be able to get more than a weeks usage out of the waste toner container.
Hope this helps.
Aug 23, 2017 | Xerox Office Equipment & Supplies
Waste toner
You have to "tell" the printer that you have "emptied" the receptacle. Depending on the model of printer, you may either need to replace it, or use the controls on the printer to "logically" do a "reset" operation.
Apr 16, 2010 | Ricoh Aficio CL7200 Laser Printer
Where is the waste toner receptacle located on the canon IR 3300i
Lower rear right portion has a small vertical panel held by one screw. The waste bottle is behind this panel.
Aug 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imagerunner c2880 (GPR-23)- Waste receptacle
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon NP6050 Waste Toner Cartridge
You can do it on your own. There's actually instructions on the LED display but it went something like:
1) open front (access door for toner area)
2) Slide blue handle up to open position.
3) Remove was toner receptacle.
Now since I didn't have a new waste toner, I just dumped out all the toner and re-inserted it. I imagine there may be some repurcussions or the toner is hazardous, I'm not sure. I'll actually get the waste toner cartridge for next time though.
Mar 21, 2008 | Canon NP 6050 Copier
Error code: 7410
Hy, i have had the same problem.
turn the power switch to off,
open the left cover,
push on the label
close the left cover
turn the power switch to on
Jan 30, 2008 | Kyocera FS-2000D Laser Printer
How to empty waste toner on an NP6030
Hello Efren. You will need to replace the drum.On your machine,the toner that could not be transferred to the paper (there is always a small amount of the copied image that cannot be successfully be transferred to the paper and must therefore be removed to make the drum ready for the next image) is deposited into a receptacle inside the drum.The copier has a sensor that lets it know that this receptacle is full. So despite the fact that the drum may still have a useful surface for making future copies it does not have the ability to store the waste toner. If you know how to replace the drum, I am pretty sure that this model can have the drum "cavity" either emptied or vacuumed in effort to squeeze out more yield than the manufacturer hoped you could if you know what I mean. Look for a a round plastic plug/orifice which can be removed and either emptied(be careful) or vacuumed. I hope I have helped you, I will gladly help you further if you need. SPINAL
Jan 17, 2008 | Canon imageCLASS D761 Copier
Having trouble replacing waste toner receptacle on Canon imageRunner 3750
If the copier indicated to empty the waste toner you will have to reset in the counter in service mode. Press the additional functions key, the 2 & 8 keys at the same time, then the additional function key again. This should get you into service mode. If not depress the reset key and try again. Once there at the top right you will see counter. Depress it then you should see a menu and depress MISC. Depress WST-TNR, then depress "C" on keypad. Counter should go to all 0's. I think that the waste toner message displays at 250,000 copies made.
Jan 07, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5570 Copier Logo
279 people viewed this question
old marine
old marine
